Tom's Hardware > Forum > Games General > Games General Discussions > Difference in wiring between cabinet and cocktail?
Forum Games General : Games General Discussions - Difference in wiring between cabinet and cocktail?
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hello -
After having searched, I really haven't found anything on the matter.
Is there a material difference in wiring between a cabinet and a
cocktail configuration?
Taking Pac-Man as an example, the cocktail has no marquee (but has two
illuminated control panels), and has two joysticks (and only two player
select buttons).
Sponsored Links
it depends wildly on the game... obviously games that played alternatly with
only a single set of controls will have the biggest differences. Ones that
had two distinct control sets will have fewest. Some have lights, some
don't... (shrug)
<mhedges@prw.net> wrote in message
news:1121709627.109755.302250@g43g2000cwa.googlegroups.com...
> Hello -
> select buttons).
Reply to Anonymous
You do have a second set of controls, as well as a Player 2 start button.
But one of the little differences that you often have to look hard to find
is the wire that tells the motherboard that it's in a cocktail cabinet
instead of an upright. This is a little trick that enables the same
motherboard to be used in either cabinet without having to move a DIP switch
or anything. It's often called "TABLE" or "COCKTAIL". With _Pac Man_ and
_Ms. Pac_, it's a wire in position R on the main edge connector socket that
is grounded to tell the board that it's in a cocktail cabinet. This wire is
not installed in the wiring harness for an upright cabinet.
Reply to Anonymous
<snip>
Thanks for the tip! What about the second joystick wiring? I'd
imagine it's additional wiring on the connector?
Reply to Anonymous
<snip>
imagine it's additional wiring on the connector? I just haven't looked
at schematics, so I'm wondering if there's different schematics for
uprights and cocktails, hence the initial post all along.
Thanks again.
Reply to Anonymous
Mmm... some snafu in the prior post - my apologies. Both posts should
have been together, i.e.-
Thanks again.
Reply to Anonymous
There are 1149 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
