Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Internet Connection Sharing (ICS) problem with XP SP2 (sim..
Forum Windows XP : General Discussion Internet Connection Sharing (ICS) problem with XP SP2 (sim..
Archived from groups: microsoft.public.windowsxp.network_web,microsoft.public.windowsxp.help_and_support (More info?)
I'm sure the answer is here, but there are thousands of ICS messages
to sort through. Summary: I have two PCs connected by ethernet, and
one PC, main, connected to the internet by USB cable modem. Everything
works fine, except the second PC can't access the internet! Any help
finding a quick answer?
Win XP/SP2 on both PCs, via the wizard, internet sharing is enabled on
PC1, and the laptop.
The laptop that is connected to my desktop via NICs using a crossover
cable. This works fine, I can read and write files between PCs from
either direction. For purposes of networking between PCs, I'm a happy
camper! Any help finding a quick answer why PC2 can't access the
internet? Buying more hardware is not an option. First is the
laptop's ipconfig, then the desktop's. TIA!
Windows IP Configuration
Host Name . . . . . . . . . . . . : loptap
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8139/810x
Family Fast Ethernet NIC
Physical Address. . . . . . . . . : 00-90-F5-0D-38-06
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
C:\WINDOWS>ipconfig /all
Host Name . . . . . . . . . . . . : desktop
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
DNS Suffix Search List. . . . . . : voliacable.com
Description . . . . . . . . . . . : Realtek RTL8139/810X
Family PCI Fast
Ethernet NIC
Physical Address. . . . . . . . . : 00-0F-EA-21-4D-56
IP Address. . . . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . : voliacable.com
Description . . . . . . . . . . . : Terayon Cable Modem (NDIS 5)
Physical Address. . . . . . . . . : 00-E0-6F-AF-07-EF
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 85.202.142.126
Subnet Mask . . . . . . . . . . . : 255.255.248.0
Default Gateway . . . . . . . . . : 85.202.136.1
DHCP Server . . . . . . . . . . . : 82.144.192.43
DNS Servers . . . . . . . . . . . : 82.144.192.40
82.144.192.50
Lease Obtained. . . . . . . . . . : Friday, June 10, 2005 10:37:00 AM
Lease Expires . . . . . . . . . . : Friday, June 10, 2005 12:37:00 PM
C:\WINDOWS>
You can only have ICS enabled on one computer, the one that connects to the internet.
http://webdiary.smh.com.au/archive [...] 01075.html
"Mister Tomato" <MrTomato@ketchup.com> wrote in message news:qkjia15gugmjla0frj3bfacpf4uvmivfus@4ax.com...
> Family PCI Fast
> Ethernet NIC
> 82.144.192.50
> C:\WINDOWS>
Reply to Anonymous
Thank you for the quick reply! I made mistake in my previous post.
ICS is on only the main PC.
Reply to Anonymous
I did make a little progress. If I enter the actual IP numbers for a
site on my client/laptop PC, not the www.whateversite.com name, it
works great! That is, it looks like the DNS is not resolving
www.whateversite.com into it's 999.999.999.999 IP numeric address. Is
there a setting I should alter so that my client PC uses the correct
DNS?
---later---
Hey!!! SUCCESS!!! I manually entered the DNS numbers in my client from
the host I found by ipconfig/all, it works great! Thanks for all the
help, it kept me on the correct path!! :))
Reply to Anonymous
There are 2004 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 16 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
