Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
A software install left computer hurting. The digital monitor gets no signal
when computer is turned on. A remote desktop connection can be made through
a networked computer. The hard drive and networking is functioning. Is
there anything I can do through a remote connection to restore the display
signal to the problem computer? Display shows "analog/digital" message then
"going to sleep" on display power on/off. Keyboard and mouse work though I
can't see what I'm doing.
Simply reboot the affected PC in Safe Mode or VGA Mode. You can then
reinstall the video drivers, if necessary, or simply reset the display
settings to a configuration that the monitor can handle.
I would do that except upon boot the monitor never gets a signal. No Windows
start up logo or nothing, just a black screen. My next course of action will
be to test the video card with another monitor. Another piece of information
- the problem started with a system crash on restart. A newley installed
McCafee program required a computer restart and the problems began after
that.
> Bruce Chambers
> Help us help you:
> http://dts-l.org/goodpost.htm > http://www.catb.org/~esr/faqs/smart-questions.html >
> You can have peace. Or you can have freedom. Don't ever count on having
> both at once. - RAH
You have to press <F8> very early in the process, immediately upon the
completion of the motherboard's POST (power-on Self test). You can see
that, can't you? If not, then your problem is purely a hardware issue,
and has naught to do with Windows.
That's a good idea. The only reason I usually don't suggest it
immediately is that few people, myself included, have extra monitors
lying about.
> that.
An installation of software gone horribly awry could conceivably cause
problems for the video drivers, but cannot possibly have affected the
hardware.
