G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Alright, I was wondering if maybe some of you with a little technical savvy
could help me fix this!
Anyways, I have an Asteroids Deluxe, with a WG V2000 in it, B&W vector
monitor, of course.
When I first got the game, it had an issue where the monitor wouldn't come
on sometimes when you powered up the game, and you'd get the red light to
blink on the deflection pcb, and then go out. Turn it off and on a few
times, game would pop right up.
So, eventually it got worse and worse until you couldn't get the monitor to
come up, period, just get the red light to flash, then nothing but a dead
red light and a dead monitor, while the rest of the cabinet came up.
So, I ordered a cap kit, with the 4 transisters that go on the side from Bob
Roberts...I installed it earlier, and it was really pretty easy, very
similar to the couple dozen or so cap kits I've put into Raster monitors.
I put the monitor back in, plug it up, turn the game on, and everything
comes up, but nothing from the monitor, although the red light on the
deflection board is now on solid, so that's good... then, I smell and see
smoke, pull the plug, and find out by looking at the deflection board that I
forgot to plug the yoke back in!
So, I plug the yoke back in (4 prong plug), check everything else, turn it
on, and the monitor gets heater glow, the red light is on steady on the
deflection board, nothing smokes or smells, but there's no picture. I've
checked all the connections, so I assume I've smoked something.
Does anybody have any suggestions on where to start?
Any help will be greatly appreciated!
Ron
Charlotte, NC
monitor, of course.
Ron
Charlotte, NC
