Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > .NET Framework 1.1 problem
Forum Windows XP : General Discussion .NET Framework 1.1 problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
PLEASE don't ask me why but I deleted it in the Add/Remove folder and
realized then that I had a big problem because I thought I could download it
off the internet and get it back - but see that it was already installed in
the computer when I got it with SP1 and can't download it apparently from
Windows website? I have SP2 installed but had deleted that uninstall folder
in Windows to save space, thinking that I wouldn't need that anymore. So,
thinking that I could get back to where I was before I deleted .NET Framework
1.1, I used System Restore - but it wouldn't get back ALL the files and I
need to repair the .NET Framework files because the Dell Support doesn't work
either (I guess without the .NET Framework not working?).
In Administrative Tools = the Microsoft .NET Framework 1.1 Configuration - I
get an Error: Fatal Execution Engine Error (0x7927e03e). I click OK. Then
I get mmc.exe - Common Launguage Runtime Debugging Services -- Application
has generated an exception that could not be handled. I click OK and get out.
And Microsoft .NET Framwork 1.1 Wizards won't open up either - I get the
same Fatal Execution Error and click OK. Then I get ConfigWizards.exe -
Common language Runtime Debugging Services -- Application has generated an
exception that could not be handles. I click OK instead of cancer, this time
too.
Is there a way to repair the .NET Framework 1.1? I only have the Dell
Reinstallation CD for my Windows XP Home Edition, Including Service Pack 1a
and I was hoping there would be some way easier than using that to fix this
problem????
Hope you can help.
lme
Reply to Anonymous
Sorry for a few unimportant errors but the important things, I hope, are
right in this!! lme
> too.
> problem????
> Hope you can help.
> lme
Reply to Anonymous
http://support.microsoft.com/defau [...] -us;824643
How to troubleshoot Microsoft .NET Framework 1.1 installation issues
if required
Microsoft .NET Framework Version 1.1 Redistributable Package
http://www.microsoft.com/downloads [...] laylang=en
Then download:
Microsoft .NET Framework 1.1 Service Pack 1
"lme" <lme@discussions.microsoft.com> wrote in message
news:2E523E03-7996-4AD0-A670-4C5B45330AC2@microsoft.com...
> too.
> problem????
> Hope you can help.
> lme
Reply to Anonymous
I'm having a problem manually removing the .NET Framework 1.1 from the
Windows Installer cache. I right-click the Windows Installer file that has
the Microsoft .NET Framwork 1.1 RTL x86 enu and then click Uninstall but I
get the message --- Windows Installer: This patch package could not be
opened. Verify that the patch package exists and that you can access it, or
contact the application vender to verify that this is a valid Windows
Installer patch package.
That is the first step towards manually removing the .NET Framework 1.1 and
it doesn't work.
Can I ignore this message and then go ahead and follow the rest of the
directions or should I stop here and do something different???
This is complicated for a 67 year old diabetic - maybe I know enough to be
dangerous when I'm trying to fix this, but I am game to follow your
directions!
lme
> if required
> Then download:
> > too.
> > problem????
> > Hope you can help.
> > lme
Reply to Anonymous
Try manually downloading Net Framework and see if you can get it to install
Then download:
With regard to Windows Installer
Description of the Windows Installer CleanUp Utility:
http://support.microsoft.com/defau [...] -us;290301
Windows Installer Cleanup Utility
http://download.microsoft.com/down [...] msicuu.exe
Windows Installer 3.1 now available for XP
http://www.microsoft.com/downloads [...] layLang=en
> that has the Microsoft .NET Framwork 1.1 RTL x86 enu and then click
> Uninstall but I get the message --- Windows Installer: This patch
> package could not be opened. Verify that the patch package exists
> and that you can access it, or contact the application vender to
> verify that this is a valid Windows Installer patch package.
> 1.1 and it doesn't work.
> to be dangerous when I'm trying to fix this, but I am game to follow
> your directions!
> lme
>> if required
>> Then download:
>>> and realized then that I had a big problem because I thought I
>>> could download it off the internet and get it back - but see that
>>> it was already installed in the computer when I got it with SP1 and
>>> can't download it apparently from Windows website? I have SP2
>>> installed but had deleted that uninstall folder in Windows to save
>>> space, thinking that I wouldn't need that anymore. So, thinking
>>> Framework
>>> and I need to repair the .NET Framework files because the Dell
>>> Support doesn't work either (I guess without the .NET Framework not
>>> working?).
>>> Configuration - I get an Error: Fatal Execution Engine Error
>>> (0x7927e03e). I click OK. Then I get mmc.exe - Common Launguage
>>> get the
>>> ConfigWizards.exe - Common language Runtime Debugging Services --
>>> Application has generated an exception that could not be handles.
>>> I click OK instead of cancer, this time too.
>>> Dell Reinstallation CD for my Windows XP Home Edition, Including
>>> Service Pack 1a and I was hoping there would be some way easier
>>> than using that to fix this problem????
>>> Hope you can help.
>>> lme
Reply to Anonymous
Is the reason that I can't uninstall the Microsoft .NET Framwork 1.1 RTL x86
enu from the Installer because I have the SP2 installed and the uninstall
file for SP2, I have deleted from Windows $uninstall files!!? I think I'm
learning what to do by following someone else's advice on doing that and then
finding out that was what NOT to do TOO late!?
So far any adivice that you've given doesn't fit my situation and doesn't
work - because when I deleted the .NET Framework 1.1 from the Add/Remove
Program, found out that was not the thing to do, and then used System Restore
to get it back - the settings came back but not the part needed to make it
work and now it won't uninstall from the Add/Remove Program anyway, I suppose
because I have SP2 installed!
Otherwise I guess I will be faced with creating a CD using AutoStreamer to
Slipstream XP SP2 to the XP Installation CD and then using that to repair my
XP first -OR- just reformat the drive and start over. Unless you have
another sugestion for still another way so that I don't have to do that????
(This is a Dell Dimension 8300 with XP Home Edition including SP1a that I'm
using which is on the Reinstallation CD.)
Thank you for your time trying to help me. Let me know if I will have to
get out my Reinstallation CD, yet.
lme
> Then download:
> > your directions!
> > lme
> >> if required
> >> Then download:
> >>> Framework
> >>> working?).
> >>> get the
> >>> Hope you can help.
> >>> lme
Reply to Anonymous
Hi there, the only other suggestion after you slipstreamed your SP2 patch with your
original WinXP disc is
http://www.updatexp.com/scannow-sfc.html
Introduction to using scannow sfc (system file checker)
Your situation is not looking good from this angle, You may be looking at
repair/reinstallation as you mentioned.
If you can, back up your files of importance before proceeding.
I made the suggestions in hope that perhaps the above procedure wouldn't be
necessary.
Sorry I couldn't help.
Kaylene
news:EA2EC37D-2A69-400F-8AF4-A2B57F26B64B@microsoft.com...
> lme
>> Then download:
>> > your directions!
>> > lme
>> >> if required
>> >> Then download:
>> >>> Framework
>> >>> working?).
>> >>> get the
>> >>> Hope you can help.
>> >>> lme
Reply to Anonymous
This is terrible, but I can't click on the "question" to post a new
question!! It keeps just showing me a bar at the top that says "click here to
view blocked pop-ups" and when I do it still doesn't give me a blank box!!
Ok, my problem is I keep getting a "ycommon.exe" error... what is it and how
can I fix it?? I hope someone can get this question and help me with an
answer!
Thanks
Hummer Chick
Reply to Anonymous
Contact yahoo sbc. It is a problem with their browser.
"That Chick with the Hummer"
<ThatChickwiththeHummer@discussions.microsoft.com> wrote in message
news:DF28F1A5-0099-4D0E-AF54-1D70367C641B@microsoft.com...
> to
> how
> answer!
> Thanks
> Hummer Chick
Reply to Anonymous
There are 1996 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 16 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
