deb
98
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have tried to install a program and it was telling me ms dos and microsoft
windows applications was not suitable for running. so, anyway I think I got
that fixed now I THINK. But now when I try to open after it installs it
says, Outline index not found. I have no clue hopefully you all can figure
out what is going on....
G
Guest
Guest
You appear to be getting an error message associated with Borland's Delphi
software.
I would use Google to search for newsgroups where you can post your issue in
the hopes that you might get better feedback. I don't think you will get
much help here in this XP newsgroup, but I could be surprised. It wouldn't
be the first time - as some posters here have a broad range of knowledge.
You may find too few postings in these newsgroups for Delphi. If so then I
would see if you can locate a forum or message board on the web.
Like it, or not, this is one of the downsides of using software that was
developed with non-Microsoft development tools. They may, and often do, run
just fine. But if you encounter problems, then frequently newsgroup support
is severely lacking.
Good luck.
Michael
"Deb" <Deb@discussions.microsoft.com> wrote in message
news:9ACBDE67-A7DA-42CF-BC02-04B71E77AE0A@microsoft.com...
>Microsoft
> got
> figure
