john
Splendid
Aug 25, 2003
3,819
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
hi,
my monitor settings all of a sudden got messed up and the setting buttons
haven't changed my monitor. The shape of the monitor was set to a shape that
I cannot change. I'm wondering how do you set the monitor back to default
settings or if there's a way to fix it?
G
Guest
Guest
John wrote:
> hi,
If the monitor's controls no longer work, and the display is unusable,
it's probably time to get a new monitor. Monitors can be repaired, but
it usually costs more than they're worth.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
G
Guest
Guest
> buttons haven't changed my monitor. The shape of the monitor was set
> to a shape that I cannot change. I'm wondering how do you set the
> monitor back to default settings or if there's a way to fix it?
Is it actually settings ON the monitor or in your software for your video
output from your video card to the monitor?
If the former - don't know - you didn't mention the name brand of the
monitor/model number/etc. Even if you did - I likely couldn't tell you the
exact method to reset it to factor defaults using its controls - but its
manual may be able to (or those who made it - like their web page...)
If the latter - don't know - you didn't mention the video card or drivers
you have installed. You also did not mention that if you boot in dafe mode
if things are more "normal" or not.. You could download/install/configure
the latest drivers from the video card manufacturer web page.. That might
help.
Shenan Stanley
MS-MVP
john
Splendid
Aug 25, 2003
3,819
It's a Hp pavilion m70, the monitor is still usuable, but I can't reconfigure
it back to the full screen setting.
> help.
> Shenan Stanley
> MS-MVP
G
Guest
Guest
> video output from your video card to the monitor?
> you the exact method to reset it to factor defaults using its
> controls - but its manual may be able to (or those who made it -
> drivers you have installed. You also did not mention that if you
> boot in dafe mode if things are more "normal" or not.. You could
> download/install/configure the latest drivers from the video card
> manufacturer web page.. That might help.
> reconfigure it back to the full screen setting.
Monitor Manual (for download in PDF format):
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=60974&lc=en&cc=us&dlc=en&lang=en&cc=us
( Short link: http://snipurl.com/fj4u )
Shenan Stanley
MS-MVP
john
Splendid
Aug 25, 2003
3,819
Thanks for the help, the problem is just with the display-
Normal Display: |----|
My Display: )----(
> Shenan Stanley
> MS-MVP
G
Guest
Guest
> the monitor/model number/etc. Even if you did - I likely couldn't
> tell you the exact method to reset it to factor defaults using its
> My Display: )----(
Ah - use the manual and find out how to change the " pincushion/trapezoid "
settings.
Shenan Stanley
MS-MVP
