Archived from groups: alt.internet.wireless (More info?)
Thanks for you answers so far, guys!
OK, im going to go ahead and try to set up a wireless link without LOS, with
some 21db antennae. I guess Im going to have to beam through the attic of a
particularly unfortuately situated tall house plus a few trees.
My question is how can I set up the equipment when I cant see it. I can do
the compass bearing thing easy enough, but I guess alignment is pretty
critical. Is there any sensitive signal meter equipment I can use (like you
use for aligning satellite dishes) or is it just trial and error?
Would welcome your suggestions
Adrenalin
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.657 / Virus Database: 422 - Release Date: 14/04/2004
"adrenalin" <billclinton@aol.com> wrote in
news:c5v7br$blm$1@news8.svr.pol.co.uk:
> can do the compass bearing thing easy enough, but I guess alignment is
> pretty critical. Is there any sensitive signal meter equipment I can
> use (like you use for aligning satellite dishes) or is it just trial
> and error?
How many meters is it?
Well, there are WiFi signal strength tools you can buy, but trial and error
is probably cheaper.
Or, you can hook up a laptop on the remote end... and get someone to
monitor the link quality tool that is usually bundled with the wifi
drivers.
Typically, it is easier to use a compass and a person on each end. They are
easier to align than you may think. Rule of thumb is only move one end at a
time.
Step 1 - Start with both antennas approximately at the correct Up/Down
angle. In my case it is always level cause we live in flat country.
Step 2 - Align the left/right one end at a time, try to get the best
strength possible on both ends, one at a time. Keep fine tuning till you
have that correct.
Step 3 - Align the Up/Down again, one end at a time. Again get the best
signal possible.
You are done.
It is not difficult when done slow and with a friend on both ends. Use cell
phones or radios to talk and do not cheat or rush. You will do OK.
Good Luck.
Michael
"adrenalin" <billclinton@aol.com> wrote in message
news:c5v7br$blm$1@news8.svr.pol.co.uk...
with
a
you
> Adrenalin
"Michael" <teknowene@excite.com> wrote in message
newsLLgc.177037$Ig.8190@pd7tw2no...
are
a
> time.
> have that correct.
> signal possible.
> You are done.
cell
> Good Luck.
> Michael
What is the probability of getting this to work without LOS?
I have a very similar scenerio. I would like to link a house that is .8 mile
(1280 M) away. The obstacle is the roof of a tall wood frame house that has
asphalt shingles and a tree right behind the house. The roof is 250 ft (76
M) from me.
> with
of
> a
do
> you
> > Adrenalin
With an external antenna with OVER KILL on the DB it is no problem
typically. I have one site that we beam right through a Concrete hotel with
no issues. It is a little less than standard but it works. When id doubt
USE TOO MUCH power you can always reign back to reduce signal if you are the
one is a hundred that have a problem with too much signal.
Michael
"George" <George@nospam.invalid> wrote in message
news:h_-dnUUiIvyb0hjd4p2dnA@adelphia.com...
> are
at
> a
> > time.
you
> > have that correct.
> > signal possible.
> > You are done.
> cell
> > Good Luck.
> > Michael
mile
has
> M) from me.
LOS,
> > with
> of
> > a
can
> do
(like
> > you
> > > Adrenalin
news:UUmhc.194193$oR5.59014@pd7tw3no...
with
the
> Michael
What high gain antennas do you like that look good on a house?
That depends. Typically it is not an issue what it looks like, but I have
used flat panels because you can paint them etc, The problem is that you
need to tune the antenna, normally this is better if you have full movement
range. Normally, a grid is best, panels are second. You will get some
debate over this, but in my experience this is the case.
Michael
news:5N6dnZ7dxOrckxXdRVn-gQ@adelphia.com...
> with
doubt
> the
> > Michael
> Thanks
