Yes No
Ads
Tom's Hardware > Forum > Windows 7 > Drivers > [Solved] USB2 0 MFP(Hi-Speed)
Forum Windows 7 : Drivers [Solved] USB2 0 MFP(Hi-Speed)
Best answer from saran008.
Have 2 printers (HP OfficeJet J6480) and EPSON NX410 which I cannot get to print, scan, etc. I get error message can't find USB2.0 MFP(Hi-Speed) driver. Anyone -Please help. becky_long@bellsouth.net
Reply to bl1936
Seems to be USB driver problem.
Have you installed all the latest motherboard drivers including USB drivers??
Try unplugging the printers & plug them in other ports.
Have you installed printer drivers for both of the printers, if not so, do them first & try again!
For your HP printer, download the latest drivers (select 32/64 bit Win7) from here
http://h10025.www1.hp.com/ewfrf/wc [...] t=3635378&
For Epson printer, get it from here
http://www.epson.com/cgi-bin/Store [...] e=Overview
You must not post your personal mail id here expecting reply.
You have to login this forum to check for your replies/answers.
------------------------------ If you think this post was the most helpful, please remember to click on"SELECT AS BEST ANSWER"!
Reply to saran008
Advice was great. I had several motherboard drivers to update. Got all to update except for USB drivers. Win7 won't recognize the updated driver hence, no installation. I have latest printer drivers and I think that it is the USB drivers that is precluding the devices from installing. I am still working on it. Thanks for your help. Won't list my email address again.
Reply to bl1936
Best answer
Give us your System/Mobo make/model.
Try downloading latest drivers from manufacturer's site & Try installing them
Reply to saran008
Hope your problem is solved & Happy to see that!
Thanks for selecting mine as Best answer :)
You are always welcome to this forum with any kind of system problems!
We are here to help you any time.
Reply to saran008
I could not find any updates for the drivers of my system in the web.
my system is "dx7380 MT" of HP make with windows vista Business (32bit) OS
Please help me
Regards
Reply to abraja
I found the issue loading a 2480 color HP printer and why it did not work. There is a setting on the printer itself and services that the default setting is to turn off high speed USB. Just change the seeting to on and you should be fine. Once I enabled that it stated printing. Hope this helps.
Reply to millerdog
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 2014 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Moving an operating system
By Pinhedd, 11 hours ago:
You will not be able to drag and drop the files because that will not copy the parts of...
Best offers
Top experts
