Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless B slower than Ethernet?
Forum Wireless Networking : Wireless General Discussions - Wireless B slower than Ethernet?
Archived from groups: alt.internet.wireless (More info?)
Why is my Wireless (802.11b) connection sustantially slower than my Ethernet
connection?
The configurations for the two machines are...
- wireless (802.11b) on Win98 box through USB 1.1
- ethernet connection on W2K box.
I tried downloading a 3.2Meg file [1] simultaneously. The ethernet box took
14sec. That translates to a throughput of 1.8Mbps (3.2m*8/14sec=1.8Mbps).
The wireless box took over a minute.
I thought...
-USB 1.1 runs at 12Mbps
-802.11b runs at 11Mbps
-my internet connection runs at 1.8Mbps
Then, the USB 1.1 AirLink adapter shouldn't be the bottleneck. Any clue?
-w
[1] http://www.tucows.com/preview/198107.html
Sponsored Links
In article <tEZgc.12914$dZ1.1856@fed1read04>,
wendi <FreeOfSpam_wendikun@NO_SPAM_hotmail.com> wrote:
:I thought...
: -USB 1.1 runs at 12Mbps
: -802.11b runs at 11Mbps
802.11b's signalling rate is 11 megabits per second. Many of those bits
are used for preambles, requests to send, pauses between frames,
beacons, and error correction. The maximum end-to-end througnput
you can get with 802.11b depends on whether you are using udp or TCP,
and for the TCP case would be in the range of 5 to 6 megabits per second.
That assumes the maximum signalling rate is being used, that the signal
is strong enough for the maximum rate -- and it assumes that there
is no radio interference.
Tenser, said the Tensor.
Tension, apprehension,
And dissension have begun. -- Alfred Bester (tDM)
Reply to Anonymous
802.11b can theoratically reach speeds of 11Mbps. In reality, you will only
get half that, 5Mbps.
There could also be factors such as interference from things like other
users on the same channel, cordless phones and microwaves.
Ray Taylor
"wendi" <FreeOfSpam_wendikun@NO_SPAM_hotmail.com> wrote in message
news:tEZgc.12914$dZ1.1856@fed1read04...
Ethernet
> connection?
took
> I thought...
> -w
Reply to Anonymous
Yeah, I read it at...
http://www.overclockercafe.com/Rev [...] Actiontec_
pg4.html
It's an old 2002 though...
Anyways, I'm not getting anything close to 5Mbps. My speed test reveals
that the ethernet connection is ~1.8Mbps. And, the wireless USB is 6 times
slower!!! Something is not right!
"Ray Taylor" <administrator@kaycee.co.nz> wrote in message
news:40848608$1@news.orcon.net.nz...
only
> Ray Taylor
> Ethernet
> > connection?
> took
> > I thought...
clue?
> > -w
Reply to Anonymous
On Mon, 19 Apr 2004 19:35:56 -0400, in alt.internet.wireless , "wendi"
You say you measured this by downloading a file simultaneously from the
internet, and you have a 1.8Mbps internet connection? Then it doesn't
matter how fast your ethernet card is, 1.8 is the best you get (and thats
what you saw). By the way, thats a very fast internet connection. Are you
on a company LAN connection? Are you sure you're performing a fair measure
if so, remember company bandwidth is shared.
And then of course, you're halving each machine's performance further, by
downloading simultaneously..... do one at a time!
Possibly in this case the bandwidth was totally absorbed by the ethernet
machine, which then relinquished bandwidth only when finished.
>And, the wireless USB is 6 times slower!!! Something is not right!
As for the wireless, I'd expect that to be about 3-10x slower I'm afraid.
Even with excellent signal strength you'd get no better than 4Mbps from an
11b card, and with poor strength the performance could easily drop to
0.5Mbps or worse.
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.angelfire.com/ms3/bchambless0/welcome_to_clc.html>
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Reply to Anonymous
In practice, I can see quite good speeds.
For example, at 5.5Mbps, I see well over 80% throughput.
(I hope to see similar results with 11g after I replace the 10base2
section of my network.)
Reply to Anonymous
> .......1.8 is the best you get .... By the way, thats a very fast
Hm... The average residential speed in California is ~1.6Mbps. 1.8 is very
reasonable.
I did one at a time, and also at different times. The results are somewhat
consistent for my non-scientific test. I can see why you would prefer the
different time method as it makes the math easier (no sharing bandwidth). I
choose the simultaneous method because usage of the destination site varies
from time to time. I realized that both methods are not very reliable. I
should really do my test through a speedtest site.
> As for the wireless ... you'd get no better than 4Mbps...
I understand that I would not get anything more than 5Mbps[1] for wireless
USB. My point is the wireless USB should not be the bottleneck. The
internet connection (1.8Mbps) which is subtantially lower than the wireless
USB should be the bottleneck. Hence, the wireless USB should be able to
provide 1.8Mbps.
-w
[1] See my previous post for reference
"Mark McIntyre" <markmcintyre@spamcop.net> wrote in message
news:8u6b80hdlete0fu2ki64rs0c967hnhaocc@4ax.com...
> 0.5Mbps or worse.
> Mark McIntyre
News==----
Newsgroups
Reply to Anonymous
> is very reasonable.
>> further, by downloading simultaneously..... do one at a time!
> somewhat consistent for my non-scientific test. I can see why you
> would prefer the different time method as it makes the math easier
> (no sharing bandwidth). I choose the simultaneous method because
> usage of the destination site varies from time to time. I realized
> that both methods are not very reliable. I should really do my test
> wireless USB. My point is the wireless USB should not be the
> bottleneck. The internet connection (1.8Mbps) which is subtantially
> lower than the wireless USB should be the bottleneck. Hence, the
> wireless USB should be able to provide 1.8Mbps.
> -w
>>> reveals that the ethernet connection is ~1.8Mbps.
>> the internet, and you have a 1.8Mbps internet connection? Then it
>> doesn't matter how fast your ethernet card is, 1.8 is the best you
>> get (and thats what you saw). By the way, thats a very fast
>> internet connection. Are you on a company LAN connection? Are you
>> sure you're performing a fair measure if so, remember company
>> ethernet machine, which then relinquished bandwidth only when
>> finished.
>> afraid. Even with excellent signal strength you'd get no better than
>> 4Mbps from an 11b card, and with poor strength the performance could
>> easily drop to
>> 0.5Mbps or worse.
>> Mark McIntyre
>> CLC readme:
>> News==---- http://www.newsfeed.com The #1 Newsgroup Service in the
>> World! >100,000 Newsgroups ---= 19 East/West-Coast Specialized
Some sites will give priority download speed to the first download from
a given IP address with the second download slowed. This prevents
bandwidth bandits from stealing their show. One test I use is to ftp
download from file storage on my ISP, and late at night local time. I
get the most consistent download estimates this way.
Q
Reply to Anonymous
If you have access to a Unix or Windows command line somewhere on the wired
network, you can run iperf to get some readings on the speed. This will
still share a connection with other uses, but the reports are very stable
and reasonable. From my Unix ISP shell, I run
iperf -s -w 256k ( or some other reasonable window size )
on my Windows box I run
iperf -c ISP-unix-ip-address
This shows speed from the client to the server.
I can't reverse those roles because of NAT firewall.
If I run between two systems inside my network, I can use iperf in either
direction, or even test both ways simultaneously with -d
iperf -c server-ip-address -d
The bidirectional only works on some server/client pairs.
iperf might allow you to nail down where a problem resides.
http://dast.nlanr.net/Projects/Iperf/
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Reply to Anonymous
Just jumping into this thread so might be unrelated but...
My broadband connection regularly gets me more than 7.5mbit/second
(950Kbytes/second). Definately faster than a wireless B router would
provide.
news:qIohc.17950$dZ1.12299@fed1read04...
very
> reasonable.
by
somewhat
I
varies
wireless
> provide 1.8Mbps.
> -w
reveals
thats
you
measure
by
afraid.
an
> > 0.5Mbps or worse.
> > Mark McIntyre
> > CLC readme:
> News==----
> Newsgroups
Encryption
Reply to Anonymous
Wow! Would you mind telling us which area are you in? Cable or DSL?
"Noozer" <postmaster@127.0.0.1> wrote in message
news:0nzhc.199514$Ig.45402@pd7tw2no...
> provide.
> very
> > reasonable.
> by
> somewhat
the
bandwidth).
> I
> varies
I
wireless
> wireless
> > provide 1.8Mbps.
> > -w
> reveals
the
> thats
> you
> measure
> by
ethernet
> afraid.
from
> an
> > > 0.5Mbps or worse.
> > > Mark McIntyre
> > > CLC readme:
> > News==----
>100,000
> > Newsgroups
> Encryption
Reply to Anonymous
Quaoar,
Would you try the following site and post your results... Just click on
personal test. This site allows 3 tests per day.
http://www.bandwidthplace.com/speedtest/
I'm getting ~1.3mbps for the ethernet. And, ~600kbps for the wireless.
These numbers seem more reasonable than my non-scientific test.
-w
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news:yaCdne3ukqIIDRvdRVn-hQ@comcast.com...
> Q
Reply to Anonymous
I can also point out that in New Zealand we have internet connections
through DSL running from 128k up to 5.8mbps as well as satellite access
which is even faster.
Ray Taylor
news:YuKhc.19592$dZ1.15624@fed1read04...
> > provide.
is
> > very
> > > reasonable.
further,
> > by
> > somewhat
> the
> bandwidth).
> > I
> > varies
reliable.
> I
> wireless
> > wireless
to
> > > provide 1.8Mbps.
> > > -w
"wendi"
> > reveals
> the
doesn't
> > thats
Are
> > you
> > measure
further,
> > by
> ethernet
> > afraid.
> from
> > an
to
> > > > 0.5Mbps or worse.
> > > > Mark McIntyre
> > > > CLC readme:
> > > News==----
> >100,000
> > > Newsgroups
> > Encryption
Reply to Anonymous
> connection?
You don't state the speed of your Ethernet: 10Mbit/s, 100Mb/s, or 1Gb/s.
That cannot be a 10Mbit/s ethernet. It must be 100Mbit/s at a minimum.
There's your reason. You expect 11Mb/s to be faster than 100Mb/s? Duh.
> I thought...
Reply to Anonymous
> pg4.html
That's because your computation is in MBytes/second, not Mbits/sec. You're
comparing incompatible units.
> only
> > Ethernet
> > > connection?
> > took
> > > I thought...
> clue?
Reply to Anonymous
Calgary, Canada... And DSL will NEVER see those speeds. Cable all the way!
> > provide.
is
> > very
> > > reasonable.
further,
> > by
> > somewhat
> the
> bandwidth).
> > I
> > varies
reliable.
> I
> wireless
> > wireless
to
> > > provide 1.8Mbps.
> > > -w
"wendi"
> > reveals
> the
doesn't
> > thats
Are
> > you
> > measure
further,
> > by
> ethernet
> > afraid.
> from
> > an
to
> > > > 0.5Mbps or worse.
> > > > Mark McIntyre
> > > > CLC readme:
> > > News==----
> >100,000
> > > Newsgroups
> > Encryption
Reply to Anonymous
On Sat, 24 Apr 2004 02:02:09 GMT, "Noozer" <postmaster@127.0.0.1>
nonsense. The G.dmt standard is for 8 Mbps ADSL and in Japan services
are running at 28 M with upgrades to 45 M in the pipeline.
Phil
Reply to Anonymous
On 04/19/04 17:02 wendi spoke:
> connection?
> I thought...
> -w
Maybe your ISP is using a proxy to cache results.
Many ISPs do that now.
Remove .NOSPAM from my email address to reply directly.
Reply to Bob
"wendi" <FreeOfSpam_wendikun@NO_SPAM_hotmail.com> wrote in message news:<tEZgc.12914$dZ1.1856@fed1read04>...
> connection?
> I thought...
> -w
I am having the same problem and have been searching for a answer for
almost a year now, there is none!. I 'think' it is more likely the
wireless system and/or the wireless receiver/card driver related issue
here.
I have used QCheck to verify the speed between CAT5 connect and
wireless connect, the CAT5 give me 9+/- while the wireless is 4.4+/-.
Some posts claimed that it is due to the wireless system's half-duplex
method and overheads. If this is true, then we should still get HALF
of what CAT5 connect gets, instead I am having 1/3 or lower while
surfing and d/l.
If you do find a solution, please do share with us.
MR814v1 + USB Phoebe wireless card.
Reply to Anonymous
"Nice4" <nice4@yahoo.com> wrote in message
news:88a0c64a.0404252030.76ceaa34@posting.google.com...
Ethernet
> > connection?
took
> > I thought...
clue?
> > -w
> here.
> surfing and d/l.
9? 4.4? What?
....and I don't know where you went to school, but 4.4 is almost exactly half
of 9, not a third.
Reply to Anonymous
On 25 Apr 2004 21:30:39 -0700, in alt.internet.wireless , nice4@yahoo.com
>> connection?
>here.
Guys, this is practically a FAQ.
This has been explained about a zillion times. A google groups search of
this group would turn up answers.
Reduction factors:
1) half duplex
2) wireless protocol overheads
3) transmission quality.
Getting 4.4Mbps from your wireless is actually quite good.
Mark McIntyre
Reply to Anonymous
> Reduction factors:
> 1) half duplex
Well the 4.4Mbps is very good I agreed, but when it comes to internet
d/l, it is a major problem. Lets put it this way, assumed the wired
connection d/l from a site for 120KB/s +/-, if I do the same d/l from
the same site at the same time via wireless connection, I will only
gets around 50~60KB/s. So it seems the 4.4Mbps is helpless at all. I
wonder what if I have an 11G with 54Mbps enabled, under the same
situation describled aboved, what could be my d/l speed?
Thinking of 11G solution. BTW, can a 11G wireless adapter works with
a 11B wireless router in 11Mbps connection ?
Reply to Anonymous
Nice4 wrote:
>>Reduction factors:
>>1) half duplex
The key is "at the same time". 120KB/s D/L speed may well be the limit
of your path from your ISP, so running two D/L's concurrently can only get
a total of 120 KB/s, split in your case by the wired and the wireless
PCs.
What do you get when you D/L single-stream to the wireless PC?
Cheers, Bob
Reply to Anonymous
On 6 May 2004 08:15:46 -0700, in alt.internet.wireless , nice4@yahoo.com
(Nice4) wrote:
>> Reduction factors:
>> 1) half duplex
Eh? Sure, if you have a 10MBps link to the internet, then its a bottleneck
having to "do" wireless at 4.4MBps. If you have a 10meg internet connection
tho, you can afford a better wireless network.
Then you have a network problem which has nowt to do with wireless.
There's no way that the wireless part can impact the internet connection
d/l speed.
Mark McIntyre
Reply to Anonymous
On Thu, 06 May 2004 15:21:49 GMT, in alt.internet.wireless , Bob Willard
>PCs.
Hah. I mentioned this in my first post, and assumed he'd already fixed that
mistake. Then I re-read his last post, and you're right, he's still testing
the wired on its own, then starting a 2nd download and is surprised that
the speed falls off...
Mark McIntyre
Reply to Anonymous
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
