G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I am trying to upgrade from ME to XP. Close to the end of installation I get
an error message that seems to relate to memory. The screen suggests I
disable my cache, cache level 2, shadowing and disable write behind. The
problem is my bios seems to have changed during this process. The bios just
shows the total amount of cache and it is not in the section that I can
highlight and change. I have been able to disable write behind on my hard
drive. I also increased my memory from 256 to 384. The message also
suggested copying XP to my hard drive for installation. Just wondering if
anyone has any thoughts on this. Copying the disk to my hard drive might
seem like the best way? My system is a HP Pavilion, AMD 900 Thanks...
