Replacement battery for Acer d250 1165
Hello,
I recently ordered a replacement for my netbook battery which is rated at 11.1 volt 2200 mAhr, and the number UMO8A41 on the battery label.
The battery I received is rated at 10.8 volts 2200 mAhr, and the number UMO8A31 appears on the label.
Is this battery OK for this computer? The outfit I bought it from doesn't seem to know the technology well enough to put my mind at ease. I am inclined to return this unit and have been trying to learn more about the situation but have found no good answers.
Can y'all help?
4 answers Last reply
More about replacement battery acer d250 1165
  1. the one you got will be having less power to work that the one you use http://www.ebay.ca/itm/Battery-Acer-eMachine-eM250-UM08A41-UMo8A41-/150911565072?pt=Laptop_Batteries&hash=item232307bd10 adding this the umo8a31 dont show your system when your search for her
  2. Thank you. I was afraid the outcome would not be good. I will return this battery and hope to find the correct one.
  3. do you have a store like this around your place http://www.batteriesexpert.com/
  4. It doesn't matter,10.8 or 11.1 can fit your laptop.
Acer Battery Netbooks Laptops
