Archived from groups: rec.games.video.arcade.collecting (More info?)
Hello!
I just pulled my games out of storage, and Defender is doing something
weird. When you first turn it on, you get a millisecond of the startup
sound, and then it goes quiet.
I ran through the RAM/ROM tests, and the test says everything is okay.
I next did the sound check, and none of the 31 sounds make any noise.
When I hit that black push button switch on the sound board, it makes that
repeat test sound over and over, but no regular game sounds. That told me
the speaker was not cutting out - so it is not the speaker. That's all I
know!
Schnoodle <violenttot@hotmail.com> wrote:
: Hello!
: I just pulled my games out of storage, and Defender is doing something
: weird. When you first turn it on, you get a millisecond of the startup
: sound, and then it goes quiet.
: I ran through the RAM/ROM tests, and the test says everything is okay.
The ram/rom test doesn't check anything on the sound board.
The only test for the sound board is that switch which doesn't really
test anything.
: I next did the sound check, and none of the 31 sounds make any noise.
: When I hit that black push button switch on the sound board, it makes that
: repeat test sound over and over, but no regular game sounds. That told me
: the speaker was not cutting out - so it is not the speaker. That's all I
: know!
: Any ideas/answers?
Could be just about anything... bad rom, bad ram, bad PIA..
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
"Schnoodle" <violenttot@hotmail.com> wrote in message
news:BF261F80.66F38%violenttot@hotmail.com...
> Hello!
> know!
> Any ideas/answers?
> Thank you!
