Problem with charging
I have a serious problem with my notebook.when i put the charger in it just doesn't charge ,i have to hold it with my finger or do some tricks .what's the matter?
2 answers Last reply
More about problem charging
  1. Sounds to me like the charger socket in the laptop might have a bent pin or missing part or suchlike in the female section.
    Or the charger has a bent or missing part, in the male section.
    You could:
    Try and fix yourself (not really easy to recommend) by seeing if you can identify which part is mishapen, and then trying to correct the shape. If you are missing a part, though, then this wont work.
    Take to a local laptop repair center / shop.
    Contact the manufacturer.
    Not really much you can do over the internet about damaged hardware.
  2. thank you for replying
Acer Notebooks Laptops
