Tech help
Archived from groups: rec.games.video.arcade.collecting (More info?)
Haven't spent much time at the bench for the past couple of years, and
I'm experiencing a color problem w/ Robo. Thought I'd ask if anyone has
any suggestions where to start...
Gameplay is unaffected, most of the time (90%) game colors are spot on
and bright, but occasionally, I'll get some transitional color streaking
across the screen, inversions, etc. I did pull and clean the RAMs a
couple of weeks ago, repair all cold solder joints and checked power,
but didn't change anything.
I'm thinking something loose on the neckboard?
http://www.classicade.com/temp/robo1.jpg
http://www.classicade.com/temp/robo2.jpg
http://www.classicade.com/temp/robo3.jpg
http://www.classicade.com/temp/robo4.jpg
http://www.classicade.com/temp/robo5.jpg
http://www.classicade.com/temp/robo6.jpg
http://www.classicade.com/temp/robo7.jpg
Bret Pehrson
bret@classicade.com
Classicade
4 answers Last reply
More about tech help
  1. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Anyone have any thoughts on this, or see something similar in the past?
    Thanks
    Bret Pehrson
    bret@classicade.com
    Classicade
  2. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Try clean and restting the Roms.
    Also check video connector on the CPU.
    Might be something simple
  3. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Try clean and resetting the Roms.
  4. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Looks like a monitor/wire problem. Something is loose either on the monitor
    chasses or the cables/connectors from the CPU board to the monitor. May just
    be bad solder connection on the chasses video input connector.
    "Bret Pehrson" <bret@classicade.com> wrote in message
    news:7Z8Ne.13929$Co1.10627@lakeread01...
    > Thanks
    >> couple of weeks ago, repair all cold solder joints and checked power, but
    > Bret Pehrson
    > bret@classicade.com
    > Classicade
Games Video Games
