Razer Blade?
oecen
Hi Guys,
I was looking at buying the new razer blade and I was wondering whether you guys could tell me whether it would be a worth while deal.
I'm looking at playing high end games like Battlefield 3 and Skyrim on it at the highest settings.
Processor
Intel® Core™ i7
Quad Core Processor with Hyper-Threading
CPU: 2.2GHz (Base) / 3.2GHz (Turbo)
Chipset
Intel® HM77 Express Chipset
Memory
8GB Dual Channel DDR3 at 1600MHz
Storage
500GB 7200RPM HDD (Primary Storage)
64GB SATA III SSD with NVELO
Dataplex™ Software
(Cache Acceleration)
Graphics and Video
Integrated Intel® GMA HD – Mobile Mode
NVIDIA® GeForce® GTX 660M 2GB GDDR5
VRAM with NVIDIA Optimus™ Technology
Display
17.3” Full HD 16:9 Ratio, 1920x1080
LED Backlit
Additional Features
Razer™ Switchblade User Interface
Razer™ Anti-Ghosting Keyboard
Razer™ Synapse 2.0 Enabled
Built-in HD Webcam (2.0MP)
Built-in Speakers
Integrated Digital 7.1 Surround Audio Support
(via HDMI 1.4) Dolby® Home Theater® v4
Audio
1x HDMI 1.4 Audio and Video Output
3x USB 3.0
1x 3.5mm Audio Microphone/Headphone
Combo Jack
1x Kensington Lock
Power
Integrated 60Wh Battery
Compact AC Adapter (120Watt)
Communications
1x Gigabit Ethernet Port
1x Integrated Intel Wi-Fi 802.11 A/G/N
1x Integrated Bluetooth® 4.0
Size and Weight
Width: 16.81 inches (42.7cm)
Depth: 10.90 inches (27.7cm)
Height: 0.88 inches (2.24cm)
Weight: 6.6 pounds (2.99kg)
Processor
Intel® Core™ i7
Chipset
Memory
Storage
Dataplex™ Software
Graphics and Video
Display
LED Backlit
Additional Features
Built-in Speakers
Audio
3x USB 3.0
Combo Jack
1x Kensington Lock
Power
Communications
Size and Weight
6
answers
Last reply
More about razer blade
Getting the Razer Blade is not about getting the most bang fore the buck in a gaming laptop, there are better options elsewhere (Sager, MSI). The Blade is much more4 about aesthetics, the thing that a laptop looks more like a laptop than a desktop-replacement that needs 4 fna and gets really hot.
So, if you are looking at the Blade as the best offer available, then no
But if you are looking for a good looking laptop than you can move from one side of your room to the other and that doesn't burns your jeans while you are using it, then go ahead and buy the Blade, the hardware is there, and it can play games at decent resolutions, so the choice is up to you -
The blade is a sort of the replacement for the discontinued 17 macbook pro.. and it might technically fit the gap of an ultrabook 17" laptop.. but if you were to buy the blade, be sure to weigh in the cost although it may look good.. be sure to ask yourself can it play the games you want at high res for the price...
It's basically fitting higher end parts into an ultra book body. Obviously, ultra books normally run you for a lot more money, and there's no difference here. If you need something portable and sleek, it'd be nice. If not, it's not worth it.
You're basically asking is an ultra book worth the extra. It's debatable and purely personal preference.
Related Resources
Razer
Laptops
Product
Related Resources
- Razer Blade help plz!
- Which Razer Edge model should I get
- Have a Razer Blade with a
- Razer Announces 2nd-Gen Blade: More Power, Lower Price
- The Razer Blade is a Stunning New 17" Gaming Laptop
- Razer Blade Gaming Laptop Now Ships with Windows 8
- Razer's Second-Generation Blade Notebook Review: Focusing On The Z
- 'Razer Blade' laptop using the GeForce 555M... underpowered?
- Razer Taking Pre-Orders for Blade Gaming Laptop Within Days
- PAX Prime 2012: Photos of the Quad-core Razer Blade Refresh
- Calculating wired to be used.
- Razer Tiamat 7.1
- New system build and dual channel question
- Can I use a EVGA GeForce GTX 560
- Need help finding laptop please
