G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hi all!
My Gravitar monitor went out on the second day of the CA Extreme show a
couple of weeks back, and I'm now starting to try to get it back working. I
know a few folks were disappointed that they didn't get to play this game on
Sunday at the show...sorry about that, but we all know how finicky these XY
monitors can be sometimes...I've actually rebuilt this monitor with Bob
Roberts kit and it has the LV2000 installed as well so I thought I'd be
pretty safe, but I guess nothing is guaranteed in life, eh?. Well...maybe
death and taxes...
Anyway, the spot killer is on and neck glow is there, and I think I hear the
deflection chatter? But absolutely no picture, even when I turn the
brightness up all of the way...not even the center dot.
I found that R920 in the High voltage cage was fried so I replaced
that...still nothing. BTW, is the red light on the high voltage board
supposed to be "on" or "off?" Also, what is the voltage that is supposed to
be going to the HV cage?
Now here's the odd thing:
One of the chassis deflection transistors was giving me a continuity "beep"
on my meter so I replaced it. Before re-powering up the monitor, I checked
the continuity with this new transistor and it was absent (no beep). Then
when I powered the monitor up...now I'm getting continuity with the chassis
again for this transistor only. None of the other chassis transistors
give continuity with the chassis.
I'm still a little green on testing the chassis transistors themselves (to
see if they're blown or good)...I've read the XY FAQ, but it still escapes
me a bit...I'll have to reread it and try again...anyone able to explain
this process clearly?
Any ideas on the continuity problem I'm having or other ideas out there?
Jon
Hi all!
death and taxes...
Jon
