Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > control panel stuck in catagory view.
Forum Windows XP : Windows XP General Discussion - control panel stuck in catagory view.
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have windows XP pro SP2. I am not able to view my control panel in
classic view. All I see on the left pane under see also is Windows
update, Help and Support, and other control panel options links.
Nothing else. I checked the registry for decimal entry. It is set to 1.
I try to reset it to 0 and close. I reopen and it is 1 again. Please
help.
Sponsored Links
Above the section in the left pane that has a box that says "See also", do
you also see a box just above that just says "Control Panel"? If so, then if
the Control Panel box has a arrow on its right-side pointing *down* -- click
that down arrow and then click "Switch to Category View".
<culver.brian@gmail.com> wrote in message
news:1119573527.811065.172810@z14g2000cwz.googlegroups.com...
> help.
Reply to Anonymous
"Switch to Classic View" option is missing in the Control Panel Common
Tasks:
http://www.winxptutor.com/cpclassic.htm
Ramesh, MS-MVP
Windows Shell/User
Windows XP Troubleshooting
http://www.winhelponline.com
http://windowsxp.mvps.org
Windows XP Newsgroup Setup Instructions for Outlook Express:
http://www.microsoft.com/windowsxp [...] setup.mspx
> help.
Reply to Anonymous
thank you so much that was it. I appreciate the help.
Brian
Reply to Anonymous
thank you so much worked flawlessly
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
Brian
Reply to Anonymous
i guess that was posting after all:)
Reply to Anonymous
You're welcome
You're welcome
You're welcome
You're welcome
Ramesh, MS-MVP
Windows Shell/User
"control_freak777" <culver.brian@gmail.com> wrote in message
news:1120015354.006835.61330@f14g2000cwb.googlegroups.com...
> Brian
Reply to Anonymous
haha
Reply to Anonymous
Ramesh, MS-MVP
Windows Shell/User
news:1120017812.984943.319970@g44g2000cwa.googlegroups.com...
> haha
Reply to Anonymous
There are 1358 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
