Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Sounds and Audio Device Problems
Forum Windows XP : Windows XP General Discussion - Sounds and Audio Device Problems
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Ok the other day this was working fine. I haven't done anything to the
sound card/drives/windows stuff ect. well i noticed my sound icon wasnt
in my task bar so i went to go put it in their. When i go to click on it
says:
Error: WIndows cannot display the volume control on the taskbar because
the Volume Control program has not been installed. To install it, use
Add/Remove Programs in Control Panel.
I have looked in the add/remove programs and i dont know about anything
in there. Then i also went to the windows programs in the add/remove
programs and i couldn't find anything on sound devices or anything of
that sort. I have had it do this to me before but i dont remember what
i did. If anyone can point me in the right directin that would be
great.
I have a VIA AC'97 built in card . Its 6.1 sourround. I also have a SB
Live! that i use for input only becuase the mic on the onboard hasnt
really worked in a long time. But everything has been fine till the
other day
Tweak
Sponsored Links
http://support.microsoft.com/defau [...] US;Q319095
Volume Icon Is Not Displayed in the Notification Area, and You Receive an Error
Message When You Try to Add It
> wasnt in my task bar so i went to go put it in their. When i go to
> click on it says:
> because the Volume Control program has not been installed. To install
> it, use Add/Remove Programs in Control Panel.
> anything in there. Then i also went to the windows programs in the
> add/remove programs and i couldn't find anything on sound devices or
> anything of that sort. I have had it do this to me before but i dont
> remember what i did. If anyone can point me in the right directin
> that would be great.
> other day
Reply to Anonymous
I'm dealing with this exact same problem and can't figure it out. What to
do?? I'm a beginner and don't know much about computers or the words.
> says:
> great.
> other day
> Tweak
Reply to Anonymous
There are 907 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
