I recently purchased a new ATI x800xl AGP Card for my system. When I installed into my system (board was rated for AGP 4x/8x), I noticed artifacts on the WindowsXP splash screen, so I removed the drivers that were installed (using the catalyst uninstall tool) for my 9500, but the artifacts were still there after the reboot (started, again, at the WinXP splash screen). So I went on line and looked around, tried messing with the BIOS Settings (setting AGP between 4x and 8x in BIOS), and sometimes the system would start with artifacts in 4x, and it would hang in 8x (with artifacts). So I decided to wipe my drive and re-install XP from scratch. No problems during XP setup, first time it goes to boot into XP, though, the artifacts appear again. I get into XP (VGA Mode - artifacts, we'll really just a garbled screen) and try to install Chipset drivers and ATI drivers. No difference. So I decide maybe my motherboard doesn't handle the newer AGP cards well or is the problem (it doesn't handle SATA and PATA drives installed at the same time like it's supposed to), so I get a new board and install it and same problems occur. I can get in to the system after XP startup (though the screen is distorted) and install chipset and ATI drivers, then system locks up on reboot. Ugh. I went to the store to try to exchange it, but they're out and the closest stock is over an hour away. Contact ATI but haven't gotten a response yet.
So, long story longer, my big question is do I have a bad video card or just an incompatable motherboard (the new motherboard is an ASUS P4P800S-X, the old board was an ABIT IS7-E2).
Any help would be appreciated!!!!
'Cause even Dark Lords of the Sith have to drink sometimes...
