Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Loss of Sound Due to RealPlayer
Forum Windows XP : General Discussion Loss of Sound Due to RealPlayer
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I was in the middle of playing a CD using realplayer when I loss all sound.
Nothing has brought it back. I Reloaded the drivers...all working.
Reinstalled Realplayer, etc. Still no sound. Help please.
Reply to Anonymous
I would start by trying Windows Media Player so you can determine whether
you have a system problem - or a problem with RealOne Player.
"jjdaneo" <jjdaneo@discussions.microsoft.com> wrote in message
news:34EAFC53-FE32-472D-9E8D-46B7157161E5@microsoft.com...
Reply to Anonymous
Thanks for the reply. It is a system problem--no sound at all, anywhere. If
a tree fell in my computer, it wouldn't make a sound.
Reply to Anonymous
>I was in the middle of playing a CD using RealOne Player when I loss all
>sound.
> Reinstalled RealOne Player, etc. Still no sound. Help please.
Since your symptoms are so uncommon/mysterious, I would use Google where you
will find information such as the following:
1. Shutdown the computer.
2. Unplug the sound card from the system.
3. Boot to Windows XP.
4. Remove all sound card related device in the Device manager.
5. Go to the following registry and remove all sound card related sub-nodes:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\
6. Shutdown the computer.
7. Plug back the sound card.
8. Boot to Windows XP.
9. Does the system find new hardware?
10. If so, follow the steps and point to the driver you have been using.
Look in your BIOS or at the startup screen - see if the computer detects
something along the lines of 'unknown video device' or 'unknown multimedia
device'. I had a similar issue with my first Live! Platinum. The 'video
line' on it (beats me what that is ) was bad. RMA'd it and that's the result
that came back from Creative with the new card as replacement.
Go to START>SETTINGS>CONTROL PANEL>Double click on "Sounds and Audio
Devices">Click on "Audio Tab"; Under "Sound Playback" make sure DEFAULT
DEVICE is the installed sound device for your computer (example: SoundMax
Digital Audio) If it is not your installed device. click on the drop-down
list. select your device. At bottom of box. click "APPLY" then click "OK".
You should now have your sound back. Hope this works.
Go to Start > Run and type
Dxdiag.exe
Click OK
If you go to the tab "Sound", you can run a test.
Reply to Anonymous
There are 2052 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 17 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
