Advise on adding wireless to home LAN
Archived from groups: alt.internet.wireless (More info?)
Hi all.
I am after some advise re setting up a wireless access point on my LAN
at home. I currently have two XP Pro machines, one connected to the
internet via ISDN, to remote for adsl yet, and acting as a gateway via
vsocks. The second machine connects through the gateway box. I'm not
using ICS for this as I found it caused more problems than it was
worth.
I want to add a wireless access point to this setup and have a Linksys
WAP11 available. This doesn't seem to let me access at present. Have I
got this wrong or should I be using something else on the network? I'm
very rusty with all this.
Many thanks
Kev
3 answers Last reply
More about advise adding wireless home
  1. Archived from groups: alt.internet.wireless (More info?)
    On 27 Apr 2004 00:26:50 -0700, kev@kenninghall.org.uk (Kev) wrote:
    >I can access the confige from the browser and I I have set the WAP11
    >to 192.168.2.251 with the xp boxes as 192.168.2.1 and .2 I've also set
    >the WAP11 gateway IP to 192.168.2.1 which is the machine with the isdn
    >card in it.
    so the PCs are wired and both can ping the WAP11, yes ?
    where does the wireless client come into this, I've slept since
    yesterday. Can you ping the AP from the wireless client, can you ping
    the XP boxes, or is 192.168.2.2 a wireless client.
    BTW what's the right subnet mask to use with 192.168.2.x addresses,
    255.255.0.0 ?
    Phil
  2. Archived from groups: alt.internet.wireless (More info?)
    Phil Thompson <cynical_observer@hotmail.com> wrote in message news:<96ft805ont2749v9cdq4td1hsiavrhh1fg@4ax.com>...
    > >card in it.
    Yes. I can ping from within the wired network without problem. In fact
    I can see each machine from the other and access the internet and
    access the AP config screen all from within the wired network
    The wireless client is an ipaq 5550 PDA and that doesn't want to play
    at all. It see's the AP and connects to it but will not let me connect
    to any of the wired machines or the internet. I'm getting a new laptop
    for work today with wifi so I'll try that as well. As the PDA works on
    other peoples networks ok I reckon it's my setup of the network thats
    at fault.
    > 255.255.0.0 ?
    Not sure. I must admit I just set it up as 255.255.255.0 and haven't
    tried anything else.
    I have taken the vsocks server out of the equation and set up ICS on
    the gateway machine for the moment to see if I was getting a problem
    from that. Doesn't seemed to have changed anything.
  3. Archived from groups: alt.internet.wireless (More info?)
    The 192 in the first octet of the IP address indicates a Class C network.
    The default mask for a Class C network is 255.255.255.0 . With your use of
    host numbers ranging from 1 to 251 I would stick with the default.
    Ron Bandes, CCNP, CTT+
    "Phil Thompson" <cynical_observer@hotmail.com> wrote in message
    news:96ft805ont2749v9cdq4td1hsiavrhh1fg@4ax.com...
    > >card in it.
    > 255.255.0.0 ?
    > Phil
Wireless Wireless Access Internet Wireless Networking
