Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I'm having problems with the dos-prompt. If I try running the program in the
(alternate) 16-bit dos emulator ----via Command.com ---Start | Run | type
Command.com <enter>, what do I have to do, when I'm done with the dos program
to reset the computer?
If I create shortcuts to the dos-app executable & then run it by clicking on
that shortcut, how is that done and do I have to reset anything after I'm
done?
Thanks for any help you can give.
Uri
done?
Uri
