Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
The vsmon process on my system intermittently runs amok using aver 50% of
the CPU and preventing anything else from running. I tried cancelling the
process through task manager but it says I don't have authority (I have
admin privileges). I have run a full virus and spyware scan (using CA ez
Trust ezAntiVirus and Lavasoft AdAware Pro) but that showed up nothing. I'm
also using ZoneAlarm Pro.
The only thing that seems to fix it for a day or two is to reset my router
to factory default settings and then reload it off a backup I have.
My system is a P4 3.0Ghz
1Gb Ram
1.7Gb swap file
Windows XP SP2 Pro with all security patches installed
Router - Billion 7402
> 50% of the CPU and preventing anything else from running. I tried
> cancelling the process through task manager but it says I don't have
> authority (I have admin privileges). I have run a full virus and
> spyware scan (using CA ez Trust ezAntiVirus and Lavasoft AdAware Pro)
> but that showed up nothing. I'm also using ZoneAlarm Pro.
> router to factory default settings and then reload it off a backup I
> have.
> 1Gb Ram
> 1.7Gb swap file
> Thanks
"Gilgamesh" <me@spam.me.not.com> wrote in message
newsEPdJ73eFHA.3160@TK2MSFTNGP09.phx.gbl...
> 1Gb Ram
> 1.7Gb swap file
> Thanks
VSMON is the True Vector service of Zone Alarm. Can't tell you why it is
'running amok'.........mine uses little, if any, cpu cycles. You might
want to try the FAQ section of Zone Labs for info.
Heirloom, old and mowed again
> 1Gb Ram
> 1.7Gb swap file
> Thanks
After reading your post, I encountered the same thing. Vsmon is racking up
49-51% of the cpu cycles and bringing everything to a halt.....could not End
Task and had to power down to reboot. If I find the answer I will post
back, if you find it, please let me know!!
Heirloom, old and that's why one was
blank
"Heirloom" <roland58XX@XXcox.net> wrote in message
news:%23CuBo34eFHA.3328@TK2MSFTNGP09.phx.gbl...
>> the process through task manager but it says I don't have authority (I
>> have admin privileges). I have run a full virus and spyware scan (using
>> CA ez Trust ezAntiVirus and Lavasoft AdAware Pro) but that showed up
>> have.
>> 1Gb Ram
>> 1.7Gb swap file
>> Thanks
As mentioned VSmon is part of Zone Alarm and the TrueVector service. Are you
guys using the latest version of ZA there have been several updates released
since version 5.5 came out? For what its worth my vsmon is using 0% CPU but
appears to be a bit of a memory hog. You could try uninstalling ZA. You will
need to manually delete its folder. Now do a cold reboot of your system and
reinstall zone alarm.
