G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
The device is integrated in an asus l5d laptop. I beg for help upgrading
driver/firmware and solving the burning/reading problems i encounter with
this drive and his generic microsoft drivers.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programmi\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68,
size=160016 bytes, created 22/07/2004 17.33.44
Versione Nero: 6.3.1.25 (Nero Express)
Masterizzatore: <PIONEER DVD-RW DVR-K13AS>Versione: 1.11 - HA 0 TA 0 -
6.3.1.25
Driver Adattatore: <atapi> HA 0
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-K13AS>Versione: 1.11 - HA 0 TA 0
- 6.3.1.25
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-K13AS atapi Port 0 ID 0
DMA: On
DiskPeripheral : IC25N040ATMR04-0 atapi Port 1 ID 0
DMA: On
12.10.43 #23 CDR -1106 File Writer.cpp, Line 304
Errore di calibrazione dell'alimentazione
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158),
size=95360 bytes, created 19/08/2004 14.00.00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :
0 (Security Option)
Windows XP 5.1
IA32
WinAspi: -
6.3.1.25
- 6.3.1.25
DMA: On
DMA: On
Existing drivers:
Registry Keys:
0 (Security Option)
