G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
hi thanks for your help but that didnt work still cantseethe networkor
access the files
egey21
Micah E. Wrote:
> I know your problem. I have had this same issue and tried to address it
> with
> Microsoft's KB but they fairly much told me to ****-off. the issue is
> with
> windows Firewall. By default it is set to block ICMP (Internet Control
> Message Protocol) packets. The ICMP is what is needed for browsing
> workgroup
> and domains. Most likely you will be able to ping other pc on the
> network
> but not see them in Network Places.
> To resolve this follow these steps:
> 1. Right click on My Network Places then click Properties.
> 2. Right click on the network connection and click properties.
> 3. Next click on the Advanced tab.
> 4. Click on the Windows Firewall Settings button.
> 5. Now click on the Advanced tab.
> 6. Next, click on the Settings button for ICMP.
> 7.Check mark each of the listed items then OK to close and OK on the
> rest of
> the dialog boxes.
> This should take care of the problem. Please note that the reason why
> ICMP
> is off is because of ping-floods, used by hackers. But, in most cases,
> hackers won't do anything to a small network unless:
> 1. Your public IP address is known.
> 2. You have valuable information on your netowrk.
> 3. And you have ****ed-off a hacker.
> Please refer to the Windows XP Resource Kit on ICMP at the following
> address:
> http://tinyurl.com/bd47h
> Micah E.
> A+ Cert.
> "egey21" egey21.1rc3po@pcbanter.net wrote in message
> news:egey21.1rc3po@pcbanter.net...-
> i have a workgroup of 10 PC's yesterday i added a new PC and a
> laptop.
> but they cannot see the other machines on the workgroup. they are all
> set up perfectly but i dont know what is wrong can anyone help me
> PLZ.
> egey21-
egey21
access the files
egey21
> with
> with
> workgroup
> network
> rest of
> the dialog boxes.
> ICMP
> address:
> Micah E.
> A+ Cert.
> laptop.
> PLZ.
> egey21-
egey21
