Can i run my dell laptop with damage battery with ac charger
I buy my Dell laptop since May 2010, after 2 year my battery back up 30 mint, so i run my laptop with charger continue but i do not replace my battery so is this safe ?
can i run my laptop with charger with damage battery pls reply me.
2 answers Last reply
More about dell laptop damage battery charger
    Unless the battery is overheating on you, you should be fine.
  2. Yes. You'll be fine. If you are simply going to connect the laptop to the AC outlet, then you can simply remove the battery. That's what I do.
Laptops Battery Dell
