Why my laptop battery cannot support network without power supply
I try to switch on my laptop without using the power supply but only via the battery. It works, although the LCD light is dim. However, my network is cut off within a few seconds. The CPU speed is also down to the minimum.
What is wrong with it?
1 answer Last reply
More about laptop battery support network power supply
  1. Change your power options, or your battery is bad
Acer Power Supplies Support Laptop Battery Laptops
