Problems with DisplayPort
abardwell
I have a Lenovo T500 and just bought a new 27" monitor (1920 X 1080). If I plug it in with a VGA cable it works fine but if I use DisplayPort to DisplayPort it doesn't recognize the monitor... any suggestions?
abardwell
Thanks for the quick reply... it has the logo on the side and I currently have the DisplayPort cable plugged in (but its the VGA cable that's driving the monitor)... Its a Philips monitor and came with a CD that has a driver but their instructions seem wrong (I can't do what they describe)...
Hi :)
The fact a display port cable will FIT into the hole does NOT make it a display port....
Check your manual ....
All the best Brett :)
