D DejaHan Honorable Nov 26, 2012 2 0 10,510 Nov 26, 2012 #1 Hello, Can you help me get rid of this message? I clicked F1 it doesn't work. I can't get into anything.
rgd1101 Don't Moderator Nov 7, 2011 73,376 3,867 176,290 Nov 26, 2012 #2 it mean the hard drive fail. Upvote 0 Downvote
zdbc13 Distinguished Feb 7, 2012 1,887 0 19,960 Nov 26, 2012 #4 If your windows will not start, saying not boot device found, you should try the diagnostics software from the disk manufacturer: http://storage.toshiba.com/storage-services-support/warranty-support/software-utilities You may have to make a boot CD with the DOS utility or remove the drive from your laptop and attach it to another computer to use the windows utility. Or you could buy a new drive and load the operating system yourself. Upvote 0 Downvote
