XP WON'T LOAD POSSIBLE HDD PROBLEM
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
HELLO, ABOUT 3 WEEKS AGO MY XP JUST STOPPED LOADING, LIKE THE POWER CUT
OFF....I HAVE AN EMACHINES AND PURCHASED THE XP DISK...USED REPAIR, NO LUCK,
REINSTALLED, NO LUCK..WAS ADVISED IT WAS MY HDD, REPLACED THE WESTERN DIGITAL
80G DMA W/ SEAGATE 120G ATA, RELOADED XP...NO LUCK GETS STUCK AND QUITS AT
THE XP SCREEN W/ THE GREEN BAR....I WAS TOLD THE PIN STRIPS MIGHT BE
INCOMPATIBLE THE DMA=40PIN AND THE ATA=80PIN....THE ATA STRIP FIT THE SLOT IN
THE MOTHERBOARD...AT WITS END PLEASE ADVISE...THANKS!!
mike42914
19 answers Last reply
More about load problem
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    > CUT OFF....I HAVE AN EMACHINES AND PURCHASED THE XP DISK...USED
    > REPAIR, NO LUCK, REINSTALLED, NO LUCK..WAS ADVISED IT WAS MY HDD,
    > REPLACED THE WESTERN DIGITAL 80G DMA W/ SEAGATE 120G ATA, RELOADED
    > XP...NO LUCK GETS STUCK AND QUITS AT THE XP SCREEN W/ THE GREEN
    > BAR....I WAS TOLD THE PIN STRIPS MIGHT BE INCOMPATIBLE THE DMA=40PIN
    > AND THE ATA=80PIN....THE ATA STRIP FIT THE SLOT IN THE
    Sorry you rude, insolent, shouting person, you'll receive no assistance from
    me - the only place you're going is straight in my kill-file. When you learn
    to post in a manner condusive with the proper rules of netiquette then you
    might find some assistance.
    All caps is considered yelling, is incredibly rude and makes your posts
    extremely hard to read.
    Besides, what has this to do with XP's Help and Support Centre?
    How to Compose a Good Newsgroup Post
    http://dts-l.org/goodpost.htm
    How to Act Smart on Usenet
    http://www.catb.org/~esr/faqs/smart-questions.html
    Getting Your Post Noticed - and Answered
    http://www.microsoft.com/presspass/features/2001/Mar01/Mar27pmvp.asp
    How Not to Get Help in Newsgroups
    http://users.tpg.com.au/bzyhjr/liszt.html
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    "mike42914" <mike42914@msn.com> wrote in message
    news:298E038C-86B3-4D40-B08F-8B2F277CF3B2@microsoft.com...
    > LUCK,
    > DIGITAL
    > IN
    > mike42914
    Your signature shows you can switch your capital letters off. Please try
    posting that way- capitals are considered shouting and many people will
    ignore your posting.
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    I apologize, new to this. I would really like to get help with this, to be
    honest did not realize caps was on...again I am truly sorry!!
  4. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    "mike42914" <mike42914@discussions.microsoft.com> wrote in message
    news:44ED2ABE-582E-433A-A256-BE88245AA893@microsoft.com...
    Please ignore Miss Tick. She is incredibly rude and rarely posts any
    information that actually helps someone. See my other post in this thread
    for help on your problem.
    Kerry
    >> from
    >> learn
    >> you
  5. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    > LUCK,
    > DIGITAL
    > IN
    > mike42914
    We need more information in order to help you. Can you boot into safe mode?
    Are you using the 80 wire or 40 wire cable? What other hardware is installed
    in your system? Have you added any new hardware lately other than the new
    hard drive? When you reinstalled did you delete and then recreate and format
    the partition?
    Kerry
  6. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    I apologize for the rudeness. I am kind of new to this.
    > Kerry
    > >> from
    > >> learn
    > >> you
  7. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Thanks for responding, I am able to boot in safe mode, the only icon on the
    screen is the "recycle bin", I am using the 80wire ribbon strip that came
    with the hdd (black side/blue side), the only hardware is a mouse, cdrw, dvd
    rom, not sure after that, like I said I am a "rookie" :), no new hardware
    added, on the reinstall deleted the partition and created a new one, I hope
    this helps a bit. Thanks again for your response, and I apologize for the
    previous posting.
    > > LUCK,
    > > DIGITAL
    > > IN
    > > mike42914
    > the partition?
    > Kerry
  8. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:6F01875E-3055-42AB-9F08-AA939DB885AF@microsoft.com...
    It is rude to post in all caps but she could have been more pleasant about
    letting you know this.
    Kerry
    >> >be
    >> Kerry
    >> >> assistance
    >> >> from
    >> >> learn
    >> >> you
    >> >> posts
  9. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:6C8E0CB3-210A-4F76-9D3E-AF4531D627E8@microsoft.com...
    > the
    > dvd
    > hope
    > previous posting.
    When you say it quits what exactly happens? Does it just stay at the same
    screen forever or does it reboot? The fact that you can get into safe mode
    is good. On a clean install the only thing on the screen should be the
    recycle bin. That's normal. In safe mode try running some programs like
    wordpad or solitaire. and playing with the system for a while. Does it lock
    up or get any errors?
    Kerry
    >> > LUCK,
    >> > DIGITAL
    >> > AT
    >> > SLOT
    >> > IN
    >> > mike42914
    >> mode?
    >> installed
    >> format
    >> the partition?
    >> Kerry
  10. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    The computer shuts off, but the "power" light on the front stays on "amber".
    I actually have to unplug the power cable and plug it in again. Windows will
    be loading, and after playing with it gets to the screen to "install the hard
    drive" and when I click the install button, off it goes. I will try the
    wordpad suggestion. Thanks for your time.
    > > the
    > > dvd
    > > hope
    > > previous posting.
    > Kerry
    > >> > LUCK,
    > >> > DIGITAL
    > >> > AT
    > >> > SLOT
    > >> > IN
    > >> > mike42914
    > >> mode?
    > >> installed
    > >> format
    > >> the partition?
    > >> Kerry
  11. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:5FB656EC-8630-40B1-8760-E4A566404D7E@microsoft.com...
    > "amber".
    > will
    > hard
    While in safe mode click on Start => Run and type in eventvwr.msc
    This will start the event viewer. Look for any errors in especially in
    Application or System. Another thing to do is Right Click on My Computer and
    pick Properties, Click on the Advanced tab, Click on the Settings button
    under Startup and Recovery, then take the tick out of the box beside
    Automatically restart. This will cause Windows to give you a BSOD instead of
    restarting. Write down the exact error message including all the numbers
    when this happens. Post the error back here. This last one may or may not
    work. It depends where in the boot process Windows is quitting.
    Kerry
    >> > the
    >> > came
    >> > cdrw,
    >> > dvd
    >> > hardware
    >> > hope
    >> > the
    >> > previous posting.
    >> mode
    >> lock
    >> Kerry
    >> >> > CUT
    >> >> > NO
    >> >> > LUCK,
    >> >> > WESTERN
    >> >> > DIGITAL
    >> >> > QUITS
    >> >> > AT
    >> >> > THE
    >> >> > SLOT
    >> >> > IN
    >> >> > mike42914
    >> >> mode?
    >> >> installed
    >> >> new
    >> >> format
    >> >> the partition?
    >> >> Kerry
  12. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Thanks.!
    > Kerry
    > >> >be
    > >> Kerry
    > >> >> assistance
    > >> >> from
    > >> >> learn
    > >> >> you
    > >> >> posts
  13. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    thanks, i am actually reloading xp again to see what happens, i gave you
    inaccurate info, the amber light is on the hard drive working indicator and
    it stays a constant amber, the power light "green" just shuts off, I will try
    your suggestion and will advise the outcome.
    > > "amber".
    > > will
    > > hard
    > Kerry
    > >> > the
    > >> > came
    > >> > cdrw,
    > >> > dvd
    > >> > hardware
    > >> > hope
    > >> > the
    > >> > previous posting.
    > >> mode
    > >> lock
    > >> Kerry
    > >> >> > CUT
    > >> >> > NO
    > >> >> > LUCK,
    > >> >> > WESTERN
    > >> >> > DIGITAL
    > >> >> > QUITS
    > >> >> > AT
    > >> >> > THE
    > >> >> > SLOT
    > >> >> > IN
    > >> >> > mike42914
    > >> >> mode?
    > >> >> installed
    > >> >> new
    > >> >> format
    > >> >> the partition?
    > >> >> Kerry
  14. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:1F29DBFA-689B-4F94-A540-60426C551FD5@microsoft.com...
    > and
    > try
    Good luck. Let us know how you make out.
    Kerry
    >> > "amber".
    >> > Windows
    >> > will
    >> > the
    >> > hard
    >> > the
    >> and
    >> of
    >> Kerry
    >> >> > on
    >> >> > the
    >> >> > came
    >> >> > cdrw,
    >> >> > dvd
    >> >> > hardware
    >> >> > I
    >> >> > hope
    >> >> > for
    >> >> > the
    >> >> > previous posting.
    >> >> same
    >> >> mode
    >> >> like
    >> >> lock
    >> >> Kerry
    >> >> >> > POWER
    >> >> >> > CUT
    >> >> >> > REPAIR,
    >> >> >> > NO
    >> >> >> > LUCK,
    >> >> >> > WESTERN
    >> >> >> > DIGITAL
    >> >> >> > QUITS
    >> >> >> > AT
    >> >> >> > BE
    >> >> >> > THE
    >> >> >> > SLOT
    >> >> >> > IN
    >> >> >> > mike42914
    >> >> >> safe
    >> >> >> mode?
    >> >> >> installed
    >> >> >> the
    >> >> >> new
    >> >> >> and
    >> >> >> format
    >> >> >> the partition?
    >> >> >> Kerry
  15. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hello, Kerry, I reinstalled the original hard drive, since the problem
    wasn't solved w/ the new one. I ran the eventvwr.msc as advised with the
    following:
    APPLICATION:
    1. Source: Perf Net Event ID: 2002
    "unable to open the redirector service. redirector performance data will
    not be returned. error code is returned is in data DWORD 0.
    2. same as above, Event ID: 2004
    3. Source MsiInstaller, Event ID: 11931
    "product: Web Fldrs XP--Error 1931. The Windows Installer service cannot
    update the system file
    C:\ProgramFile\CommonFiles\MicrosoftShared\WebServerExtentions\40\bin\FP4AUTL.DLL
    because the file is protected by Windows. You may need to update your
    operating system for the program to work correctly. Package Version
    4.0.2.7523, OS Protected version:
    --i received this one twice...
    SYSTEM:
    Source: Service Control Manager, Event ID: 7026
    1. The following boot-start or system-start drivers failed to load: AFD,
    Fips, intelppm, IPSec, MRxSmb, NetBios, Net BT, RasAcd, Rdbss, Tcpip.
    2. same source, Event ID: 7001
    The IPSEC Services depends on the IPSEC driver service which failed to start
    because of the following error: "a device attached to the system is not
    functioning."
    3. same except for TCP/IP Net BIOS depends on the AFD service...
    4. Source: DCOM Event ID: 10005
    DCOM got error "this service cannot be started in safe mode" attempting to
    start the service event system w/ arguments "" in order to run the server
    (1BE17F766-5536-11D1-B726-00C04FB926AF)
    5. same as above except...to start the service netman w/ arguments....server
    (BA126AE5-2166-11D1-B1D0-00805FC-1270E).
    Sorry if you spent a lot of time on the previous hard drive, i really do
    appreciate your help. Thanks again.
    > > and
    > > try
    > Kerry
    > >> > "amber".
    > >> > Windows
    > >> > will
    > >> > the
    > >> > hard
    > >> > the
    > >> and
    > >> of
    > >> Kerry
    > >> >> > on
    > >> >> > the
    > >> >> > came
    > >> >> > cdrw,
    > >> >> > dvd
    > >> >> > hardware
    > >> >> > I
    > >> >> > hope
    > >> >> > for
    > >> >> > the
    > >> >> > previous posting.
    > >> >> same
    > >> >> mode
    > >> >> like
    > >> >> lock
    > >> >> Kerry
    > >> >> >> > POWER
    > >> >> >> > CUT
    > >> >> >> > REPAIR,
    > >> >> >> > NO
    > >> >> >> > LUCK,
    > >> >> >> > WESTERN
    > >> >> >> > DIGITAL
    > >> >> >> > QUITS
    > >> >> >> > AT
    > >> >> >> > BE
    > >> >> >> > THE
    > >> >> >> > SLOT
    > >> >> >> > IN
    > >> >> >> > mike42914
    > >> >> >> safe
    > >> >> >> mode?
    > >> >> >> installed
    > >> >> >> the
    > >> >> >> new
    > >> >> >> and
    > >> >> >> format
    > >> >> >> the partition?
    > >> >> >> Kerry
  16. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:CC616231-874F-462D-995A-CF00310097AD@microsoft.com...
    > following:
    > APPLICATION:
    > SYSTEM:
    > start
    > functioning."
    > arguments....server
    Hi Mike
    I'm busy with work today. I'll try to get a look at this later. In the
    meantime try http://www.eventid.net/ for some trobleshooting of the Event ID
    numbers.
    Kerry
    >> > you
    >> > and
    >> > will
    >> > try
    >> Kerry
    >> >> > "amber".
    >> >> > Windows
    >> >> > will
    >> >> > the
    >> >> > hard
    >> >> > the
    >> >> Computer
    >> >> and
    >> >> button
    >> >> instead
    >> >> of
    >> >> numbers
    >> >> not
    >> >> Kerry
    >> >> >> > icon
    >> >> >> > on
    >> >> >> > the
    >> >> >> > that
    >> >> >> > came
    >> >> >> > mouse,
    >> >> >> > cdrw,
    >> >> >> > dvd
    >> >> >> > hardware
    >> >> >> > one,
    >> >> >> > I
    >> >> >> > hope
    >> >> >> > apologize
    >> >> >> > for
    >> >> >> > the
    >> >> >> > previous posting.
    >> >> >> the
    >> >> >> same
    >> >> >> safe
    >> >> >> mode
    >> >> >> the
    >> >> >> like
    >> >> >> it
    >> >> >> lock
    >> >> >> Kerry
    >> >> >> >> > POWER
    >> >> >> >> > CUT
    >> >> >> >> > REPAIR,
    >> >> >> >> > NO
    >> >> >> >> > LUCK,
    >> >> >> >> > WESTERN
    >> >> >> >> > DIGITAL
    >> >> >> >> > AND
    >> >> >> >> > QUITS
    >> >> >> >> > AT
    >> >> >> >> > MIGHT
    >> >> >> >> > BE
    >> >> >> >> > FIT
    >> >> >> >> > THE
    >> >> >> >> > SLOT
    >> >> >> >> > IN
    >> >> >> >> > mike42914
    >> >> >> >> safe
    >> >> >> >> mode?
    >> >> >> >> is
    >> >> >> >> installed
    >> >> >> >> than
    >> >> >> >> the
    >> >> >> >> new
    >> >> >> >> recreate
    >> >> >> >> and
    >> >> >> >> format
    >> >> >> >> the partition?
    >> >> >> >> Kerry
  17. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    > following:
    > APPLICATION:
    > SYSTEM:
    > start
    > functioning."
    > arguments....server
    I quickly checked some of the errors. They don't appear to be related on the
    surface. You may have some major file corruption on that hard drive.
    Kerry
    >> > you
    >> > and
    >> > will
    >> > try
    >> Kerry
    >> >> > "amber".
    >> >> > Windows
    >> >> > will
    >> >> > the
    >> >> > hard
    >> >> > the
    >> >> Computer
    >> >> and
    >> >> button
    >> >> instead
    >> >> of
    >> >> numbers
    >> >> not
    >> >> Kerry
    >> >> >> > icon
    >> >> >> > on
    >> >> >> > the
    >> >> >> > that
    >> >> >> > came
    >> >> >> > mouse,
    >> >> >> > cdrw,
    >> >> >> > dvd
    >> >> >> > hardware
    >> >> >> > one,
    >> >> >> > I
    >> >> >> > hope
    >> >> >> > apologize
    >> >> >> > for
    >> >> >> > the
    >> >> >> > previous posting.
    >> >> >> the
    >> >> >> same
    >> >> >> safe
    >> >> >> mode
    >> >> >> the
    >> >> >> like
    >> >> >> it
    >> >> >> lock
    >> >> >> Kerry
    >> >> >> >> > POWER
    >> >> >> >> > CUT
    >> >> >> >> > REPAIR,
    >> >> >> >> > NO
    >> >> >> >> > LUCK,
    >> >> >> >> > WESTERN
    >> >> >> >> > DIGITAL
    >> >> >> >> > AND
    >> >> >> >> > QUITS
    >> >> >> >> > AT
    >> >> >> >> > MIGHT
    >> >> >> >> > BE
    >> >> >> >> > FIT
    >> >> >> >> > THE
    >> >> >> >> > SLOT
    >> >> >> >> > IN
    >> >> >> >> > mike42914
    >> >> >> >> safe
    >> >> >> >> mode?
    >> >> >> >> is
    >> >> >> >> installed
    >> >> >> >> than
    >> >> >> >> the
    >> >> >> >> new
    >> >> >> >> recreate
    >> >> >> >> and
    >> >> >> >> format
    >> >> >> >> the partition?
    >> >> >> >> Kerry
  18. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Thanks Kerry, I appreciate the time you have spent on this..no hurry, going
    on vacation this friday, any ideas on how to fix this???
    > > following:
    > > APPLICATION:
    > > SYSTEM:
    > > start
    > > functioning."
    > > arguments....server
    > Kerry
    > >> > you
    > >> > and
    > >> > will
    > >> > try
    > >> Kerry
    > >> >> > "amber".
    > >> >> > Windows
    > >> >> > will
    > >> >> > the
    > >> >> > hard
    > >> >> > the
    > >> >> Computer
    > >> >> and
    > >> >> button
    > >> >> instead
    > >> >> of
    > >> >> numbers
    > >> >> not
    > >> >> Kerry
    > >> >> >> > icon
    > >> >> >> > on
    > >> >> >> > the
    > >> >> >> > that
    > >> >> >> > came
    > >> >> >> > mouse,
    > >> >> >> > cdrw,
    > >> >> >> > dvd
    > >> >> >> > hardware
    > >> >> >> > one,
    > >> >> >> > I
    > >> >> >> > hope
    > >> >> >> > apologize
    > >> >> >> > for
    > >> >> >> > the
    > >> >> >> > previous posting.
    > >> >> >> the
    > >> >> >> same
    > >> >> >> safe
    > >> >> >> mode
    > >> >> >> the
    > >> >> >> like
    > >> >> >> it
    > >> >> >> lock
    > >> >> >> Kerry
    > >> >> >> >> > POWER
    > >> >> >> >> > CUT
    > >> >> >> >> > REPAIR,
    > >> >> >> >> > NO
    > >> >> >> >> > LUCK,
    > >> >> >> >> > WESTERN
    > >> >> >> >> > DIGITAL
    > >> >> >> >> > AND
    > >> >> >> >> > QUITS
    > >> >> >> >> > AT
    > >> >> >> >> > MIGHT
    > >> >> >> >> > BE
    > >> >> >> >> > FIT
    > >> >> >> >> > THE
    > >> >> >> >> > SLOT
    > >> >> >> >> > IN
    > >> >> >> >> > mike42914
    > >> >> >> >> safe
    > >> >> >> >> mode?
    > >> >> >> >> is
    > >> >> >> >> installed
    > >> >> >> >> than
    > >> >> >> >> the
    > >> >> >> >> new
    > >> >> >> >> recreate
    > >> >> >> >> and
    > >> >> >> >> format
    > >> >> >> >> the partition?
    > >> >> >> >> Kerry
  19. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:87A0250E-0384-4014-A71F-F17280E35A2D@microsoft.com...
    > going
    It sounds like you may have a hardware problem. Go to www.memtest.org and
    download memtest86+. Let it run for several hours and see if you get any
    memory errors. Try a different hard drive cable. Check the temperature of
    your CPU. You can usually access this in the BIOS. Those are a few places to
    start.
    Kerry
    >> > the
    >> > following:
    >> > APPLICATION:
    >> > will
    >> > cannot
    >> > SYSTEM:
    >> > AFD,
    >> > start
    >> > not
    >> > functioning."
    >> > to
    >> > server
    >> > arguments....server
    >> > do
    >> the
    >> Kerry
    >> >> > you
    >> >> > indicator
    >> >> > and
    >> >> > will
    >> >> > try
    >> >> Kerry
    >> >> >> > on
    >> >> >> > "amber".
    >> >> >> > Windows
    >> >> >> > will
    >> >> >> > "install
    >> >> >> > the
    >> >> >> > hard
    >> >> >> > try
    >> >> >> > the
    >> >> >> in
    >> >> >> Computer
    >> >> >> and
    >> >> >> button
    >> >> >> beside
    >> >> >> instead
    >> >> >> of
    >> >> >> numbers
    >> >> >> may
    >> >> >> not
    >> >> >> Kerry
    >> >> >> >> message
    >> >> >> >> > only
    >> >> >> >> > icon
    >> >> >> >> > on
    >> >> >> >> > the
    >> >> >> >> > strip
    >> >> >> >> > that
    >> >> >> >> > came
    >> >> >> >> > mouse,
    >> >> >> >> > cdrw,
    >> >> >> >> > dvd
    >> >> >> >> > new
    >> >> >> >> > hardware
    >> >> >> >> > new
    >> >> >> >> > one,
    >> >> >> >> > I
    >> >> >> >> > hope
    >> >> >> >> > apologize
    >> >> >> >> > for
    >> >> >> >> > the
    >> >> >> >> > previous posting.
    >> >> >> >> the
    >> >> >> >> same
    >> >> >> >> safe
    >> >> >> >> mode
    >> >> >> >> be
    >> >> >> >> the
    >> >> >> >> programs
    >> >> >> >> like
    >> >> >> >> Does
    >> >> >> >> it
    >> >> >> >> lock
    >> >> >> >> Kerry
    >> >> >> >> >> > THE
    >> >> >> >> >> > POWER
    >> >> >> >> >> > CUT
    >> >> >> >> >> > REPAIR,
    >> >> >> >> >> > NO
    >> >> >> >> >> > LUCK,
    >> >> >> >> >> > THE
    >> >> >> >> >> > WESTERN
    >> >> >> >> >> > DIGITAL
    >> >> >> >> >> > STUCK
    >> >> >> >> >> > AND
    >> >> >> >> >> > QUITS
    >> >> >> >> >> > AT
    >> >> >> >> >> > MIGHT
    >> >> >> >> >> > BE
    >> >> >> >> >> > STRIP
    >> >> >> >> >> > FIT
    >> >> >> >> >> > THE
    >> >> >> >> >> > SLOT
    >> >> >> >> >> > IN
    >> >> >> >> >> > mike42914
    >> >> >> >> >> into
    >> >> >> >> >> safe
    >> >> >> >> >> mode?
    >> >> >> >> >> hardware
    >> >> >> >> >> is
    >> >> >> >> >> installed
    >> >> >> >> >> than
    >> >> >> >> >> the
    >> >> >> >> >> new
    >> >> >> >> >> recreate
    >> >> >> >> >> and
    >> >> >> >> >> format
    >> >> >> >> >> the partition?
    >> >> >> >> >> Kerry
Hard Drives Windows XP
