Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
"" wrote:
> I tried the taskbar repair tool above and it did nothing.
> Mr Myth
> "Mr Myth" wrote:
> > Has anyone tried this?
> > Taskbar Repair Tool Plus!:
http://www.kellys-korner-xp.com/taskbarplus!.htm
> > Mr Myth
> > "Mr Myth" wrote:
> > > I spoke with Microsoft and after being moved around
> through various
> > > departments for about a half an hour, they said that I
> would have to do a
> > > clean install.
> > > Mr Myth
> > > "TL" wrote:
> > > > Hello David
> > > > I have a similar problem to you as per my question
> entered today but not so
> > > > severe as admin users can still login. I also deleted
> some spyware using
> > > > Ad-Aware SE Personal, A-Squared and Spyware Doctor. When
> I used the Ad-Aware
> > > > I quarantined the files and my broadband became
> disconnected. I recovered the
> > > > files and the broadband came back. I used A-Squared and
> this allowed me to
> > > > select files to remove thereby not deleting the relevant
> file to retain
> > > > online access. The Spyware Doctor has deep registry scan
> but I have not
> > > > deleted any registries. I just need all logins to
> function again as I change
> > > > these users to admin but still no login.
> > > > I have also had to do extensive defragment even though
> XP analyze said not
> > > > required.
> > > > Kind Regards,
> > > > TL
> > > > "David Ray" wrote:
> > > > > PC has suffered from spyware problems. During the
> process of trying to get
> > > > > it cleaned up (most recently, using Microsoft
> Antispyware), after a scan we
> > > > > restarted.
> > > > > Now, the logon screen comes up, you login, and it
> comes to a totally blank
> > > > > desktop. No taskbar or icons, no start button
> functionality, etc.
> > > > > Any suggestions?
> > > > > TIA
> > > > > David
This is becasue it is not the taks bar that is broken, it is explorer.
And i laph at what microsoft said to do, i can think of ways of whcih
to try and repair explorer, but it is realy complicated and realy i
would actualy have to be at the computer that is broken to make sure
all went well. but here is a "basic" out line of what i personaly
would do. I would use a proccess manger (not task manger, a much
better proces manager) use this to see what moduals explorere has
loaded and is using, if that failed i would do the same on a computer
of similare configuration, list all the moduls (litraly on a sheet of
paper) find the moduls on a computer where explorer works, copy them
to Recovary Console compatible USB flash memory, launch recovary
console, and replace all moduls using the list i made and files i had
gathered. It is a very long shot, but thats the only thing i can come
up with. Of course it can go deeper then that, if that failed what i
would then do is look at the parent proces for explorer and do exacly
the same, and keep going from parent to parent untill i reachtthe very
top, if it was not working then, it would definitly mean reinstall of
windows. please note i said "basic" at the start
EDIT: Any modules which explorer has loded that are obviusly not
suposed to be there i would delete.
Posted using the
http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL:
http://www.windowsforumz.com/Help---Support-XP-Pro-Logi...
Visit Topic URL to contact author (reg. req'd). Report abuse:
http://www.windowsforumz.com/eform.php?p=1763719
