Archived from groups: alt.internet.wireless (More info?)
I have a compaq laptop (P3 128 RAM) using comcast cable and I want to go
wireless.
I haven't done to much research on this subject, but I really don't want to
spend more than I have to.
I'm looking at Linksys Routers and PCMICA card.
What would you recommend?
Linksys 11mbps or the Linksys 54mbps routers (54mbps is twice the cost than
the 11mbps)
This laptop is mainly for surfing the web and keeping books.
Please give me advice and why one would be better than the other.
Thanks, Jeff
In article <4w5lc.9667$Ia6.1176494@attbi_s03>,
jeffrey.perron@comcast.net says...
> wireless.
> the 11mbps)
> Thanks, Jeff
Just my opinion Jeffrey...
Going on the net with a laptop using wireless networking is easy...
Going on the net with a laptop using wireless that also has your
accounting system on it (or checkbook program) is stupidity.
You are begging to be a victim of identity theft.
http://www.firewallreporting.com Personal firewall log analysis tools for
ZoneAlarm, BlackICE, WinRoute Pro and Windows XP
Take stock of your firewall settings and take action against intruders.
If you just need Internet access, 11Mbps is lot faster then you cable
connection, 54Mbps is of no advantage to you.
Linksys has good reputation. Draytek Vigor is better, but more expensive.
Presumably your banking is done via SSL encrypted websites and using
wireless connection doesn't make any difference in this respect.
Nevertheless you should use firewall, wifi / WEP encryption and MAC
filtering.
Regards,
Martin
In article <mbbb905qp1gq2iat5enjl9bea7t7lmvl4r@4ax.com>,
Doug Jamal <unimportantbishiv6atyahoodotcom@yahoo.com> wrote:
n Mon, 3 May 2004 02:08:36 +0100, "Martin²" <never@give.one> wrote:
:>If you just need Internet access, 11Mbps is lot faster then you cable
:>connection, 54Mbps is of no advantage to you.
:<snipped>
:What?!?
You disagree, Doug? Your cable connection runs at 5 Mbps or higher,
the effective throughput of 802.11b ? Or you know a way to squeeze
more than 5 Mbps of LAN-side throughput through a cable connection rated
at only about 2.5 Mbps ?
If you have -local- LAN accesses, then Yes, 54 Mbps *might* be better
for you -- but Martin² started with "If you just need Internet access",
which doesn't apply to the LAN-access case.
Admit it -- you peeked ahead to find out how this message ends!
On 3 May 2004 03:40:16 GMT, in alt.internet.wireless ,
>:<snipped>
>:What?!?
I think doug might have been noting that while its true that the speed of
your internet connection will be well below that of the wireless, if you
have a network ,then internet traffic is not all there is.
For example I stream audio round my house via a mostly wired 10/100
network, and although its nice to be able to listen to music in my garden
via a wireless enabled device, 11b only just cuts that mustard, and I get
quite a few dropouts.
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.angelfire.com/ms3/bchambless0/welcome_to_clc.html>
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Thanks!
On Mon, 03 May 2004 11:28:07 +0100, Mark McIntyre
>>:<snipped>
>>:What?!?
First of all, I was not disagreeing. Was I a bit surprised? Yes.
Apparently, I learned something new today and I am grateful for it.
Thanks for the reply.
On 3 May 2004 03:40:16 GMT, roberson@ibd.nrc-cnrc.gc.ca (Walter
>:<snipped>
>:What?!?
