Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Dimension 8300 Powerup Problem
Forum Computer Brands : Dell Dimension 8300 Powerup Problem
Archived from groups: alt.sys.pc-clone.dell (More info?)
Having kind of a weird problem and not sure of the solution. Recently I all
of a sudden had trouble turning on my computer (Dimension 8300 XP SP2). Had
to hold the power button in for as much as twenty or thirty seconds before I
could power up. Tried some different things and found that plugging into a
different port on my USP seemed to fix the problem. Two days later the
problem started up again. Took the computer off the UPS and plugged
directly into a power strip. This seemed to fix the problem and then two
days later the same problem reoccurred. I am at a loss as to what is going
on. What is most confusing is how when I plug the computer into a different
power outlet everything seems to be fine for a couple days and then the same
powerup problems resume. I have not made any changes to my system, have run
adaware and done a complete virus scan of my system. Any help would be
greatly appreciated.
Jack
Jack Ruetty
jruetty@columbus.rr.com
Reply to Anonymous
"Jack Ruetty" <jruetty@columbus.rr.com> wrote in message
news:cLzbe.685$Eg.315@tornado.ohiordc.rr.com...
> all of a sudden had trouble turning on my computer (Dimension 8300 XP
> SP2). Had to hold the power button in for as much as twenty or thirty
> seconds before I could power up. Tried some different things and found
> that plugging into a different port on my USP seemed to fix the problem.
> Two days later the problem started up again. Took the computer off the
> UPS and plugged directly into a power strip. This seemed to fix the
> problem and then two days later the same problem reoccurred. I am at a
> loss as to what is going on. What is most confusing is how when I plug
> the computer into a different power outlet everything seems to be fine for
> a couple days and then the same powerup problems resume. I have not made
> any changes to my system, have run adaware and done a complete virus scan
> of my system. Any help would be greatly appreciated.
> Jack
> Jack Ruetty
Jack,
I see your UPS mentioned a couple of times. Have you tried the unit
directly plugged into the wall outlet, and if so, same thing?
Stew
Reply to Anonymous
I agree it's probably the PS. The only commonality I can see where plugging
it into another outlet might have "helped" is that by unplugging it from one
power source to plug it into another, you interrupted constant power to the
power supply. What the actual problem with the power supply may be and why
interrupting power seems to help, I do not know. This sounds like a question
for our resident authority and my new best buddy, w_tom. So... w_tom (if
your trolling this ng)... what say you?
Reply to Anonymous
"Jack Ruetty" <jruetty@columbus.rr.com> wrote in message news:cLzbe.685$Eg.315@tornado.ohiordc.rr.com...
> could power up. [] What is most confusing is how when I plug the computer
> into a different power outlet everything seems to be fine for a couple days and
> then the same powerup problems resume. []
I believe at least some PC power supplies contain protection circuits
which, upon detecting a fault, latch the PS into a shutdown state and
in order to reset the PS you have to unplug it for a few moments and
then plug it back in. I think I've also read that some PSs can be reset
by holding the power button in for a certain amount of time. I'm not
familiar with the 8300 and its PS, but what you describe sounds
consistent with that. At least if we assume that it wasn't the different
outlets that solved the problem, but rather the simple act of unplugging
it and plugging it back in.
Have you been having any other problems with your system? Has
it been operating normally and shutting down properly? Have there
been any HW changes recently... upgrades or additions? Did you
move the system and connect it to a different circuit? Any lights
flickering or other signs that the computer is on a dirty circuit?
When you press the power button, are there *any* signs of life?
Do fans start to spin up, do any front or back lights come on...
even momentarily? Or does it just sit there as though it were
unplugged?
Reply to Anonymous
"User N" <usern@invalid.invalid> wrote in message
news:f-mdnXPepdPjvfLfRVn-uw@comcast.com...
>> seconds before I could power up. [] What is most confusing is how when I
>> plug the computer
>> days and
> unplugged?
The only significance of unplugging it and changing outlets is that it
probably allowed ALL power to dissapate from the system board and other
components (as opposed to simply turning the system off or powering it
down.).
If the OP has already plugged directly into the wall (as opposed to simply a
different plug in his surge or UPS) then it is likely the system's power
supply.
Stew
Reply to Anonymous
I don't know if this is related, but it might be. Dell tech support has
said that with the 8300's a low battery warning on startup is often
caused by a temporary loss of ground when the computer is plugged into a
surge protector. Their solution is to try unplugging the computer from
the protector or power strip and plugging it back into a different
outlet in the protector, and/or plugging it directly into the wall
outlet, and/or plugging the protector's cord directly into the wall
outlet. I have had this problem 3 times, and sure enough, I determined
that unplugging the protector's cord and replugging into the wall outlet
cured it(by trial and error I determined that the loss of ground was at
the wall outlet).
> Jack
Reply to Anonymous
I appreciate all the help and responses - I have tried all of them and still
having the same problem (when I come home from work I have to hold the power
button in for 30 to 40 seconds - then the computer boots - if I turn it off
when it is warm it powers right back up like it should) - I think the
problem is getting worse as it seems to be taking longer and longer each
day - again any help would be appreciated
Jack
Jack Ruetty
> Jack
> Jack Ruetty
Reply to Anonymous
news:vpwde.1620$Q.580@tornado.ohiordc.rr.com...
>still having the same problem (when I come home from work I have to hold
>the power button in for 30 to 40 seconds - then the computer boots - if I
>turn it off when it is warm it powers right back up like it should) - I
>think the problem is getting worse as it seems to be taking longer and
>longer each day - again any help would be appreciated
> Jack
> Jack Ruetty
Jack - did you unplug and reset the PS using the (red) voltage switch as
User N. did? (115v to 230v for a minute or two, then back to 115v and then
plug and power up...)
If so, then I'd start with replacing the power supply (after) I'd taken a
look at the internal cabling connections from the power switch to the front
I/O mini-board, and from that mini-board to the main board. Perhaps one of
the (2) necessary cables has worked a bit loose.
That's where I'd start if it were mine.
Stew
Reply to Anonymous
There are 2103 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
