Problems with Geforce MX 2
G
Guest
Guest
Hi Folks,
Installed a Geforce MX 2 yestreday. First of all I can't set all the resolutions my montior supports. It's an older monitor from Acer but in fine condition.
Second and worst of all Motion COmpensation does not work. I get lots of purple and white dots. Disabling it in WinDVD makes them go away but 90% of the reason I bought this card was for the bettere DvD playback.
Also TV-out is UGLY.
Any tips are GREATLY appreciated.
My current system:
Win 95C (Win 98 is just too fat and slow) on a
Western Digital UDMA 33 HDD, 3.1 GB, 5400 RPM, formatted in 2 partitions with FAT16
Quantum Atlas 7400 4.3 GB FastSCSI drive (mostly for writing to CDs and playing multimedia) FAT32
Quantum Atlas II 10,000 RPM UW SCSI FAT32 for video capture and games. :)
FastSCSI Adaptec 2940 (can't afford a UW controller yet) If you never want to have problems with SCSI, get Adaptec, expensive, but worth it.
Toshiba 1201 SCSI DVD drive. 5 X (OK 4.8 but the SCSI makes up for it)
TEAC 56s CD writer
AMD K6-2+ 500 Mhz (yes +) clocked to 550 Mhz)
128 MB PC 100 RAM
NMC VMX board (EpoX copy with MVP3 chipset)
External ZIP drive.
Latest drivers as far as I know.
HamsterSlayer
67
To make DVD features available, you should use that latest drivers from the card manufacturer (NOT nvidia). If there is a DVD player bundled with the card, try that in conjunction with the new drivers.
G
Guest
Guest
Well I installed the latest drivers and apparently motion comp. doesn't work at all....
Still can't get the refresh rates to work.
