Archived from groups: alt.internet.wireless (More info?)
Hi--
I'm trying to set up a home system for a friend. The basic concept is to
give him the security of a wired system when his laptop is plugged in to
the port replicator (dock) at his home office desk--yet also give him the
wireless flexibility to move to the patio or another room--plus on-the-
road wireless for his travels. The laptop will be the only computer on
the network except for the occasional guest with a laptop.
Here's what I've proposed for him:
1. HP Pavillion zt3000 Pentium M 1.6Ghz 1GB RAM 60GB HDD DVD+RW Intel Pro
Wireless 2200 811.02b/g MS XP Professional
2. Advanced Port Replicator for HP zt 3000 (dock)
3. Microsoft MN-700 Base Station 802.11g
4. HP PSC 1210 Printer/Scanner/Copier w/ Linksys Wireless-G Print Server
for USB2.0 (Ethernet connection between print server--base station.)
The port replicator connects via 10/100 Ethernet cable to the Base
Station. So at the dock he's wired. When he unplugs from the dock he's
wireless to the MS Base Station, which I will configure with the highest
security settings--WPA--I guess--turning off the SSID broadcast, etc.
If anybody sees any flaws in this--alternative
recommendations/improvements--I would appreciate it. Advice on
installation, etc. also welcome.
> Many thanks...
How are you planning on rotating WPA keys ? What no firewall on his
laptop ? Your friends laptop will be open to attack. Check out if the
linksys has broadcom chip in it. Worth checking out if it supports -
SecureEZsetup from broadcom (Not sure if all linksys has broadcom
chipset). Why are you using MS mn-700 base station ? Its reported to
have intermittent disconnects .
Bufflo has a airstation , supports AOSS (airstation one touch secure
system) . Just a suggestion . Real easy to set up.
I doubt that the combo printer/scanner/fax will do anything other than print
on the wireless mode.
Why not get a router with a built in print server and not go wireless for
the printer?
"Drew Cutter" <andrewc@wcoil.com> wrote in message
news:c76f8o$952$0@65.17.190.246...
Pro
> > Many thanks...
"Alan White" <alanwhite99xxxxxx@hotmail.com> wrote in
news:XTClc.20820$3Q4.443048@news20.bellglobal.com:
> print on the wireless mode.
> for the printer?
Thanks Alan. I think you are right.
It looks to me like the NetGear FWG114P instead ofthe Microsoft MN-700. The
NetGear piece seems to do it all. Router, Firewall, Access Point, USB or
Ethernet print server. It appears also that none of the
printer/scanner/copier devices are wi-fi compatible. HP Deskjet 5850 looks
like a nice little printer and is wi-fi compatible plus either USB or
Ethernet when the laptop is docked
>> > Intel
> Pro
>> > Server for USB2.0 (Ethernet connection between print server--base
>> > station.)
>> > he's wireless to the MS Base Station, which I will configure with
>> > the highest security settings--WPA--I guess--turning off the SSID
>> > broadcast, etc.
>> > Many thanks...
Thanks Drew. Yeah--I'm still researching the security end. I think the
NetGear router has a robust firewall. I'll also put ZoneAlarm or similar
software. Plus WPA. I don't know what you mean about rotating the keys--
haven't got there yet. Any advice is welcome.
My mn700 works just peachy
Pro
> > Many thanks...
In article <8WElc.361404$oR5.165726@pd7tw3no>, scooby@nospamcozmos.com
says...
> My mn700 works just peachy >
> Pro
> > > Many thanks...
Just be thankful Microsoft doesn't make airplanes....
But then again, if they did, there probably would not have been a 9/11
http://www.firewallreporting.com Personal firewall log analysis tools for
ZoneAlarm, BlackICE, WinRoute Pro and Windows XP
Take stock of your firewall settings and take action against intruders.
