System Restore Problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
My PC has two hard drives, C: the system drive and D: which contains all my
documents.
I tried to do a System Restore and got the following message:
"Changes made to drive(s) C:\ after this point cannot be reversed because
the drive was either excluded from System Restore monitoring, or was turned
off or removed." I've tried several restore points and always get the same
message.
I have followed the instructions for enabling the drive i.e. Control Panel-
System -System Restore but drive C: is not even shown. Under status it just
says "(D:) Monitoring".
I recently replaced the C: drive with a larger one. I did not rebuild the
system but used Drive Copy to create an image. I wonder if this might be
behind the problem.
Any advice will be gratefully received.
Nick.
7 answers Last reply
More about system restore problem
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi Nick,
    After changing the drive is seems System Restore still thinks the old
    drive D: drive is C:
    Disable System Restore from monitoring all drives. Reboot the system
    and enable SR on C:
    All restore points will be lost, but that doesn't matter much sense
    they don't work anyway.
    If the D: drive contains data files there is no need to have SR
    monitor it.
    How to Disable and Enable System Restore
    http://bertk.mvps.org/html/disablesr.html
    Here are some additional tip on keeping System Restore Healthy.
    http://bertk.mvps.org/html/healthy.html
    Regards,
    Bert Kinney MS-MVP Shell/User
    http://dts-l.org/
    > which contains all my documents.
    > message:
    > reversed because the drive was either excluded from
    > System Restore monitoring, or was turned off or removed."
    > message.
    > i.e. Control Panel- System -System Restore but drive C:
    > is not even shown. Under status it just says "(D:)
    > Monitoring".
    > not rebuild the system but used Drive Copy to create an
    > image. I wonder if this might be behind the problem.
    > Nick.
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi Bert,
    Thanks for your reply.
    I'm not able to disable SR. I check the box, click Apply and get the warning
    that I'll lose my restore points. I click OK but nothing happens.
    I have also tried this in Safe Mode.
    I've posted a screenshot of the display at
    http://www.charybdis.dsl.pipex.com/panel.html
    Only one drive is recognized.
    It looks to me as if there is some inconsistency in the registry.
    Nick.
    "Bert Kinney" <bert@NSmvps.org> wrote in message
    news:OdWN8VkhFHA.1412@TK2MSFTNGP09.phx.gbl...
    > Hi Nick,
    > and enable SR on C:
    > monitor it.
    > Regards,
    > http://dts-l.org/
    > > message:
    > > message.
    > > Monitoring".
    > > Nick.
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi Nick,
    Reinstalling System Restore should the drive letter problem.
    Note: The following file is located in a hidden folder. To view hidden
    files follow these steps:
    Open Control Panel - Folder Options - View tab, select "Show hidden
    files and folders" and uncheck "Hide extensions for known file types",
    click OK.
    Open Windows Explorer and navigate to the windows\inf folder.
    Find the sr.inf file, right click on it and select Install.
    If the Files Needed dialog box appears, click Browse and point to the
    i386 folder on the Windows XP CD or to the i386 folder on the hard
    drive, if it exists.
    Regards,
    http://dts-l.org/
    Nick wrote:
    > Hi Bert,
    > and get the warning that I'll lose my restore points. I
    > Nick.
    > "Bert Kinney" wrote
    >> Hi Nick,
    >> thinks the old drive D: drive is C:
    >> Reboot the system and enable SR on C:
    >> much sense they don't work anyway.
    >> have SR monitor it.
    >> Healthy. http://bertk.mvps.org/html/healthy.html
    >> Regards,
    >> http://dts-l.org/
    >>> get the same message.
    >>> is not even shown. Under status it just says "(D:) Monitoring".
    >>> did not rebuild the system but used Drive Copy to
    >>> create an image. I wonder if this might be behind the problem.
    >>> Nick.
  4. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi Bert,
    I followed your instructions and all is now ok.
    Thanks again.
    Nick.
    news:eUXAq6lhFHA.2852@TK2MSFTNGP15.phx.gbl...
    > Hi Nick,
    > click OK.
    > Regards,
    > http://dts-l.org/
    > Nick wrote:
    > > Hi Bert,
    > > Nick.
    > > "Bert Kinney" wrote
    > >> Hi Nick,
    > >> have SR monitor it.
    > >> Regards,
    > >> http://dts-l.org/
    > >>> Nick.
  5. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    You're welcome Nick.
    Just curious, when C: was replaced with a new drive moved to D: did
    you format the old drive or just delete the windows files from it.
    Regards,
    http://dts-l.org/
    Nick wrote:
    > Hi Bert,
    > Thanks again.
    > Nick.
    >> Hi Nick,
    >> problem.
    >> To view hidden files follow these steps:
    >> "Show hidden files and folders" and uncheck "Hide
    >> extensions for known file types", click OK.
    >> folder.
    >> Install.
    >> point to the i386 folder on the Windows XP CD or to the
    >> i386 folder on the hard drive, if it exists.
    >> Regards,
    >> http://dts-l.org/
    >> Nick wrote:
    >>> Hi Bert,
    >>> registry. Nick.
    >>> "Bert Kinney" wrote
    >>>> Hi Nick,
    >>>> matter much sense they don't work anyway.
    >>>> have SR monitor it.
    >>>> Regards,
    >>>> http://dts-l.org/
    >>>>> message:
    >>>>> be reversed because the drive was either excluded from
    >>>>> drive
    >>>>> C:
    >>>>> Monitoring".
    >>>>> problem.
    >>>>> Nick.
  6. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hey Nick and Bert, I had a similar situation when I had to replace my old
    WINXP-SP2 drive. I to bought a bigger drive and when I set up the new drive,
    it appeared to copy the entire system without a problem. When I switched
    drives and attempted to start the System Restore I would consistently get
    abends from either the 'Help System Restore' or when I tried to access it
    from the System ASR tab.
    Bert I followed your suggestion in this email by clicking on the sr.ini
    file. I am curious about this because when I pointed to my XP install cd it
    installed older files than what is currently on my system. Should this be of
    concern to me? If so, is there a simple solution to restoring the updated
    files and dll's that were replaced?
    news:uEHRSdOiFHA.1428@TK2MSFTNGP10.phx.gbl...
    > Just curious, when C: was replaced with a new drive moved to D: did you
    > Regards,
    > http://dts-l.org/
    > Nick wrote:
    >> Hi Bert,
    >> Thanks again.
    >> Nick.
    >>> Hi Nick,
    >>> problem.
    >>> folder.
    >>> Install.
    >>> Regards,
    >>> http://dts-l.org/
    >>> Nick wrote:
    >>>> Hi Bert,
    >>>> registry. Nick.
    >>>> "Bert Kinney" wrote
    >>>>> Hi Nick,
    >>>>> have SR monitor it.
    >>>>> Regards,
    >>>>> http://dts-l.org/
    >>>>>> message:
    >>>>>> drive
    >>>>>> C:
    >>>>>> Monitoring".
    >>>>>> problem.
    >>>>>> Nick.
  7. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi,
    Did you use a pre SP2 CD for the reinstall?
    Regards,
    http://dts-l.org/
    > to replace my old WINXP-SP2 drive. I to bought a bigger
    > drive and when I set up the new drive, it appeared to
    > consistently get abends from either the 'Help System
    > Restore' or when I tried to access it from the System ASR
    > tab.
    > on the sr.ini file. I am curious about this because when
    > I pointed to my XP install cd it installed older files
    > restoring the updated files and dll's that were replaced?
    >>> "Bert Kinney" wrote
    >>>> Hi Nick,
    >>>> and point to the i386 folder on the Windows XP CD or
    >>>> to the i386 folder on the hard drive, if it exists.
System Restore Windows XP
