Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
I have Adobe Photoshop and Adobe Acrobat reader. Should I uninstall them
both???
"Chelsea" wrote:
> "lexi" <lexi@discussions.microsoft.com> wrote in message
> news:CBB11F00-7848-4E41-985A-E5289611A949@microsoft.com...
> > error message says driver may need updated.
> > I have tried updating, uninstalling and it still says driver is working
> > properly.
> > But still have the problem.
> Hi Lexi,
> Do you have Adobe Type Manager installed. It is known to cause this problem.
> Adobe don't have a fix for this specific problem as far as I know. All you
> can do is remove ATM and your Standby and Hibernation mode should return.
> There are probably other utilities that bind to the Windows XP kernal so if
> you don't have ATM it might be an idea to review any software operating at
> low or operating system level on your machine.
> Chelsea
