Battery question
Last response: in Network Providers
Archived from groups: alt.cellular.fido (More info?)
Is there a the difference between 670 mAh, 700 mAh and 770 mAh?
My Sony Ericcson Li-ion 3.6 V battery says 670 mAh. I've seen 700 and
770 mAh batteries for sale and wonder if I can use those as long as the
volts are the same?
Many thanks for any advice you can give me on this before I buy the
wrong battery.
More about : battery question
> volts are the same?
If the battery is the same format (physical) and voltage then yes.
mAh is milli ampere hours. It is a measure of how much juice can be
stored in the battery: aka: how long your phone can go between recharges.
I believe that you can use them as long as they are the same voltage. I have
bought NiMH rechargeabe AA batteries which range from 2000mAh to 2500mAh and
they work in my digital devices. Because of this, I generally buy the higher
rated AA batteries since they keep my items powered longer if the price
difference is reasonable. If they are the same price, I get the higher mAh
NiMH battery.
<bobblespin@yahoo.com> wrote in message
news:1124459270.121169.131350@z14g2000cwz.googlegroups.com...
> volts are the same?
> wrong battery.
Ask the community
