Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Since I upgraded to XP service pack 2 I have started to receive an
application error popup at the time of starting up my laptop.
The popup does not come every time I start up my computer but when it comes
it is at the stage of the Novell login screen(client version 4.90.0.0 SP1a).
The pop up window looks like this:
___________________________________________________________________
Svchost.exe - Application error
The instruction at "0x02f513fc" referenced memory at "0x00000000".
The memory could not be written.
Click OK to terminate the program
Click CANCEL to debug the program
I normally click on OK and continue, sometimes I restart and the pop up
doesn’t appear again.
It happened again when I restarted after lunch and when I clicked cancel for
debugging there was no debugging happening that I can see. To make it clear,
even though I get this application error message everything seem to work
after I click on OK, to terminate the program (I don’t know what program is
terminated though). Any ideas? How do i rectify this?
You need this update fix from MS WindowsXP-KB894391-x86-ENU.
If you set up error reporting in computer management, services area, to
automatic the next time it happens just send the error report to MS and they
will automatically direct you to the patch.
j
You can also enable error reporting by right clicking on my computer,
properties, advanced, error reporting, then just check both boxes or adjust
to your needs by choosing programs.
j
Jaymon,
I installed this patch (I have the exact same error) and the problem still
exists.
Next?
Dave
> j
> Jaymon,
> exists.
> Next? >
> Dave
> > j
