Closed Solved
Acer Laptop Battery Light Blinking
Hey,my laptop battery light is flashing every so often. While using it, it will beep, and then the battery light starts flashing. If I unplug the AC adapter, and plug it back in, he problem stops for a while only to start happening again in a few minutes. Any thoughts?
Acer Aspire 7750G
6 answers Last reply Best Answer
More about acer laptop battery light blinking
  1. Best answer
    this look like you gone need another battery when it plug on ac do you see if hte battery is getting power and charge up ?
    When it's plugged in on AC it does charge however after a few minutes the issues occurs, and then after I unplug the adapter and plug it back in, it keeps charging.
  3. this realy look like the battery is having memory charge so it wont charge over that point this was a issue will old notebook memory,see this http://en.wikipedia.org/wiki/Memory_effect and you could try this to resolve it http://www.ehow.com/how_5974613_remove-memory-effect-laptop-battery.html
  4. If the battery is more than a couple years old, and/or has endured many charging cycles, it may have reached the end of its useful life.
    You should be able to find an inexpensive generic replacement on eBay. Or, for a substantially higher price, you can get a much better battery by going to a place like BatteriesPlus.
  5. Best answer selected by Brett928S2.
  6. Hi :)
    CLOSING due to age... but please start another thread if you are still having problems , which I will answer promptly...
    All the best Brett :)
Acer Light Laptop Battery Laptops Product
