problem with virtual memory,plz help!
i dont know what i did but suddenly my virtual memory is 0 and i cant change it! now i cant play games :(
when i go to system,advanced,performance,virtual memory i get this error first,before i get in the VM tab:
http://rotter.net/User_files/nor/3f74b29674f54940.jpg
then when i get in and try to change to amount of virtual memory it wont change! it always stays on 0 i reboot and all that,nothing helps :(
can someone plzzzz help me?
thanks.
(and sorry for my crap english..)
5 answers Last reply
More about problem virtual memory help
  1. Try using system restore to roll back to a point before you messed around with vm and perhaps deleted your paging file - I use restore all the time - I have a tendency to screw things up all the time ...
    <b><font color=red> “Liberals have many tails and chase them all.” – H.L. Mencken </font color=red><b>
  2. yea i wanted to do that then i checked and saw that it was set to OFF lol.. stupid me :\
    and 10x 4 trying 2 help. :]
  3. sorry - try posting Toey ...
  4. it seems that you're using winxp, right?
    <b><font color=purple>
    The real troubles in your life are apt to be things that never crossed your worried mind.
    </font color=purple></b>
    <A HREF="http://www.mapua.edu.ph/" target="_new">
    MIT
    </A>
  5. Since the page file is already set to zero, try selecting "No paging file", reboot into Safe Mode, and then delete the hidden file (C:\pagefile.sys). Then reboot again. Afterwards, set the page file as "System managed size". Reboot again. Then attempt to set the page file with a custom setting, and reboot once more.
    Be sure you do all of this using an administrative account.
    I suggest leaving a minimum sized file of 2MB on C:, if you intend to move the bulk of the page file to a partition on a separate hard drive. This really helps avoid these kind of problems in WinXP, IMHO. Look at this link for more information, under <A HREF="http://aumha.org/win5/a/xpvm.php" target="_new">Problems with Virtual Memory</A>.
    Toey
    <A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=328&s=91c282f2e5207e99b7a652ee13b3512a" target="_new"><font color=green>My System Rigs</font color=green></A>
    ___________________________________________
    <A HREF="http://forums.btvillarin.com/" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>Your Computer Questions Answered</font color=orange></i>
Virtual Memory Performance Games Windows XP
