Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Any GF2 ULTRA cards WITHOUT 2d problems?
I want to get a geforce2 ULTRA card soon, but I keep hearing about all the 2d problems. Are there any brands that DON'T have the problem? Does the Hercules card have the 2d problems?
Also, does anyone know any webpages with DETAILED instructions on doing the RIF mod?
Sponsored Links
Hercules is great company, one of best GeForce2 Ultra cards you can get, you'll be fine if you get one from them.
=Quantum
AO Admin
The Dr.Twister Network
http://ao.drtwister.com
Reply to Anonymous
As a "proud owner" of GTS I can tell that any of GTS cards have far better 2D than any card that was released 3 years ago, so if you are still uzing one of zose, you will not regret. Some body could tell ya, Radeon is king in 2D, but some body could tell ya, who cares. So ya can have ferrary that gives ya 200 mph but not pulls 4 ton cart behind, or you can have a truck that will give ya 100 mph and will pull the cart. You deside now.
"akuna mutata" braza... :wink: <P ID="edit"><FONT SIZE=-1><EM>Edited by Pumba on 03/05/01 10:51 PM.</EM></FONT></P>
Reply to Anonymous
I think he was asking if any companies make GeForce's that just aren't too good, but you are right..A GTS would be fine. Though if he isn't going for Ultra, and playing a lot of 32 bit games...i'd say go for Radeon 64 DDR (retail)
=Quantum
AO Admin
Reply to Anonymous
As far as brand goes, there is not much (if at all) difference between them. Elsa makes the best ones though as far as 2D goes (that's what I've read, did not see it myself). I have Asus 7700 one, it is fine, almost as sharp as Matrox at work. It is really hard to notice the difference if PCs are not side by side. Anyway, Radeon will do it, but I hear a lots of drivers issues with W2k and BX boards.
Reply to Anonymous
So all the brands are the same? :(
Another question, when playing a 3d game, are the textures affected by the poor 2d? Do they seem blury, or is it only evident on true 2d games/applications.
Reply to Anonymous
you'll see nothing at all if you are asking that kind of questions, trust me and buy yerself a nice vid card... its all coooll in any D with GTS.
Reply to Anonymous
Here is a site with some more info about the primary cause of the slight bluriness. It is the band-pass filter at the output designed to prevent excess radiation. Anyways, for the afflected or the curious, here is the site: <A HREF="http://www.geocities.com/porotuner/imagequality.html" target="_new">http://www.geocities.com/porotuner/imagequality.html</A> Good Luck, Take_Out
The early bird gets the worm. The early worm gets the bird.
Reply to Take_Out
I own the Hercules Prophet II Ultra and have no issues with it at all. I run both 2d and 3d games fine.
John Garrett
System Admin - www.elementk.com
Editor - Exploring Windows NT Professional
Reply to Anonymous
- 0 +
Prophet II ultra is a good card JGarrett. But the RADEON and the G450 still have better 2d Quality.
P3 500e@1ghz/i815ep/386mb/36gb/sb mp3+/radeon32mb :cool: k6-2 300/430tx/64mb/13gb/sb512/Sav4 32mb
Reply to rcf84
"P3 500e@1ghz" - hehehe, gg, hehehe, gg, hehehe, gg
Reply to Anonymous
You are probably right. The primary reason I bought the Ultra was the DVI connection for my TFT display. I have been very satisfied with it for both 2d and 3d.
John Garrett
Reply to Anonymous
- 0 +
nt
-Your Comany Names Could Be Here-
e-mail for application details.
Reply to peteb
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
