Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello:
I have been scanning other messages posted in this site about more or
less the same problem, but got no solution. So I'll ask again:
In my taskbar, the icon for volume has dissapeared.
It happened, curiously, after I checked and "cleaned" my pc from
potential damaging adware, spyware (I had it!), viruses....
I have tryed to check the box to put the volume icon again in the
taskbar ,through control panel/..., and I have ticked also the "always
show". But nothing has changed. I have done it more than once,
nothing.
I don't exactly know what it means to reboot the computer, so, if
someone thinks that it could be really useful, explain to me what it
is, please.
Also: it is possible it was moved from its place/removed because I
erased some kind of virus?? I would find it strange, but may be it is
possible...?
And, if that's the case, what could I do now??
I also tryed the Microsoft fix about the sscd and the play n drop, but
it happens that it has nothing to do with my problem with my computer
because I have a newer version; anyway, I also tried to disable this
things (the SSCD and the Play n Drop?) and set them again to the
default....Nothing changed.
I just don't know what else to try.
The truth is that I don't know almost anything about computers and I am
scared to try something even more damaging. So, please, give me simple
steeps to follow ....
Hi Beatriz,
Don't know off the top of my brain why you can't get the volume icon back
but, rebooting your computer can fix a lot of odd things so there is no
chance of damage to your computer to reboot it is a normal function you
should do at least every other day if you have DSL Etc..... , so to reboot
assuming you have winxp go to start turn off restart the computer should do
the rest. HTH (Hope This Helps)
JDHSR
"Beatriz" wrote:
> Hello:
> nothing.
> is, please.
> possible...?
> Beatriz
