Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > problem with cd writing wizard
Forum Windows XP : Windows XP General Discussion - problem with cd writing wizard
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello everyone, I just recently ran in to a problem with the CD wizard
of Windows XP.
When I try to burn data on to a CD it keeps telling me to insert a disk in
to the drive, even though there is a disk in the machine.
I have used other programs such as Musicmatch and HP's program called
Recordnow and all work just fine.
I have tried to uninstall and then reinstall the drive but to no avail.
What else can i take a look at?
Sponsored Links
> wizard of Windows XP.
> disk in to the drive, even though there is a disk in the machine.
> avail. What else can i take a look at?
Why multiple posts in different groups..?
Please cross-post as opposed to multi-posting in the future and allow 24
hours to pass before worrying if you will ever get an answer or not.
- Are you sure these are good and blank CD-R/RWs?
- You say you can burn using the other applications on this computer - why
in the world would you want to use the crippled burning of Windows XP when
you have a full-fledged application or two?
- Is the Recording properties tab of the drive setup for the drive to be
enabled for recording?
- Can you describe - in detail - what you are doing step-by-step - and the
results thereof - including messages you get, questions asked of you,
options you are choosing from, etc.
Shenan Stanley
MS-MVP
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
Reply to Anonymous
There are 1259 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
