G
Guest
Guest
Please help,
I have an Asus A7v, Amd 900 Athlon T-bird
A Geforce2 Mx Video Card from Gainward
128Mb Ram and a Sound Blaster Live Value Sound card.
It runs great until I try and play Diablo2 on it then it freezes up instantly. I did notice that there was a 3d test in the Diablo2 folder so I ran this test and it failed , it said, "Cannot play Diablo2 on this machine."
I have downloaded the latest drivers for the video card but it did not correct the problem.
I haven't tried downloading the newest Bios yet because I've heard that you have to disable something before you flash the new Bios and I don't know what it is to disable.
What gets me is I can run this game on a Pentium 233MMX with a cheap $40.00 video card from Creative. I can also run Unreal Tournament on this old machine without any problems.
I've read some feedback about compatibility problems between the chipset on the Motherboard and Nvidia chips, and I've read others saying that they work fine together.
Is there a cure for this combo
Please advise I am very frustrated
Thank You very Much
Geo
Thank You very Much
Geo
