reconnecting problem
Forum General Networking : Network General Discussions - reconnecting problem
Thanks all...
Hi, thanks for your input. I have determined that the problem is the computer. Its not connected to the network, the network cable is fine and the port is fine. There is no lite on the back of the cpu. I can't fix it.
<P ID="edit"><FONT SIZE=-1><EM>Edited by jiffy on 04/17/02 07:34 PM.</EM></FONT></P>
Sponsored Links
I'd say you going to have to wait for your sys admin to get back from vacation, but you don't have more than 1?
<font color=red>:</font color=red> <font color=white>:</font color=white> <font color=blue>:</font color=blue>
Reply to Zlash
I believe there is only one person working on the computers, where my sister works. Thanks
Reply to jiffy
Hmm that sucks.
Reply to Zlash
make sure the computer has an ip address, make sure you can ping and all that good stuff.
i went to the tomshardware forums and all i got was this lousy signature.
Reply to jihiggs
OK, thanks. I also told her to chech out the help in the windows. That should keep her busy, if she still wants to try to fix it.
Reply to jiffy
Some simple things to try:
-Using Network Neighborhood/My Network Places (*NOT my computer*) can you see the server? If so, then the drive mapping for the client machine is incorrect. Fix by right-clicking on My Computer on desptop and restoring what was already there--don't type anything new and make sure that you choose the correct drive leter.
-If you cannot see the server in net neighborhood can you see any other network resources? printers, other servers, etc? If so, then the problem is most likely with the server. If not then the machine in question may not be properly connected to the network or the domain/workgroup name being used at logon (even if automatic) is incorrect. Both of these issues will be hard to fix on your own.
You can also go and physically log onto the server itself. You might find that it's crashed and needs a restart, or something more serious has happened. If you do log onto the server and feel the need to restart it make sure that you shut it down in an orderly fashion (Start-shutdown).
"There are no mysteries with computers...just fix it you idiot!" (R. Warren 1909-1990)
Reply to Uncle_Astro
OK, thanks. I passed it alone.
Reply to jiffy
Thanks all...
Reply to jiffy
Try replacing the cable or seeing if there is any conflicts in device manager with the NIC.
Reply to Zlash
It's my sister's computer at work. She said she can't fix it. It's not her job to go out of her way to fix it. But, with everybody's help she has determine to leave it alone, and let someone els fix it. So, that puts an end to this post.
Thanks again.
Reply to jiffy
Tom's Hardware > Forum > General Networking > Network General Discussions > reconnecting problem
There are 501 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
