Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
Did that for jpe, jpg jpeg and gif.... still the same situation.
Weird!
Peter
Toronto, Canada
XP Home SP2
P4 HT @ 3ghz, 1gb RAM, 360gb HD
"Ramesh, MS-MVP" <ramesh@XOX.mvps.org> wrote in message
news:uzbYxCfjFHA.708@TK2MSFTNGP09.phx.gbl...
> See if resetting the default handler to WPFV helps.
> - Open Control Panel, Folder Options applet
> - Click the File Types tab
> - Scroll down and select the file type from the list.
> - Click the Restore button at the bottom
> Ramesh, Windows XP MVP
http://windowsxp.mvps.org
> "Peter" <ex-brit AT rogers DOT com> wrote in message
> news:OsvkttejFHA.476@TK2MSFTNGP14.phx.gbl...
>>I only have jpeg and gif stored and Microsoft Photo Editor is the default
>>here.
>> Peter
>> Toronto, Canada
>> XP Home SP2
>> news:efyh1mejFHA.3316@TK2MSFTNGP14.phx.gbl...
>>> Peter,
>>> Apart from file association settings, I don't know what's causing this.
>>> BTW, which filetype is causing this, and is WPFV the default handler for
>>> that type?
>>> news:u3R%23bgejFHA.1444@TK2MSFTNGP10.phx.gbl...
>>>> Thanks.. I should have realised that... I did it, but I still have to
>>>> go to the preview to get the menu. I wonder if recent Microsoft
>>>> Updates has caused this? I'm up to date so have no idea which one, if
>>>> it is that.
>>>> Peter
>>>> Toronto, Canada
>>>> XP Home SP2
>>>> news:%23kO$DdejFHA.3316@TK2MSFTNGP14.phx.gbl...
>>>>>>> How do you register a dll?
>>>>> regsvr32 phototoys.dll
>>>>> regsvr32 shimgvw.dll
>>>>> news:%232uZKgdjFHA.3608@TK2MSFTNGP12.phx.gbl...
>>>>>> It's exactly like the above post, nothing appears. It does work,
>>>>>> however if I click "Preview" first and THEN try resize (on the
>>>>>> preview image).
>>>>>> Peter
>>>>>> Toronto, Canada
>>>>>> XP Home SP2
>>>>>> news:eb31xiajFHA.2472@TK2MSFTNGP15.phx.gbl...
>>>>>>> Peter,
>>>>>>> Tried registering the phototoys.dll? And, do you see the dialog box
>>>>>>> when you click the "Resize..." context menu/
>>>>>>> news:Oy8WkEWjFHA.2484@TK2MSFTNGP15.phx.gbl...
>>>>>>>> Sorry to butt in...this got me to check mine...it doesn't work
>>>>>>>> either, even with that cmd fix.
