Once the install gets past the initial file copy (gets into the GUI portion of the setup), the system either locks or blue screens with various STOP errors. I've also noticed screen artifacts appearing shortly after it enters the 'GUI' portion. The STOP errors vary, but I'm getting 0x0A most of the time (with no text error, just numeric parameters). There have been a few instances where I get a box popup that says something like "a component that Windows needs to continue could not be installed."
I've destroyed the partition and started from scratch a few times now (using both the normal and 'quick' format options), and I've tried 2 different install CD's. I also tried MS's advice and turned off all caching and restarted the install, but that brought the computer to a crawl and it was getting late. I'm suspecting that I've got either a bad hard disk or bad RAM. I've got another hd I can try, but no other RAM. Anyone have any more suggestions?
Here are the core components I'm running with:
Athlon XP 2200+ (not overclocked)
Asus A7N266 mobo (built-in LAN, audio, video)
Corsair PC2100 RAM, 256MB
Western Digital 80GB 7200rpm HD
