Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Network problem...pls help
Archived from groups: microsoft.public.windowsxp.hardware,microsoft.public.windowsxp.help_and_support,microsoft.public.windowsxp.network_web (More info?)
Hi all,
I suddenly lost my connection to the internet and am not able to get it
back.
I have a cable modem with 4 computers connecting to it. 1 computer is
having problem getting access to the internet.
I suspect the problem is not able to get an IP address from the DNS of the
cable modem.
I have tried restarting the computer several times. I even changed the NIC,
but without any success.
Before the failure, my anti-virus/anti-spy software was giving me warnings
which I clicked to delete the file(s) being flagged. This probably delete
my required network software file on the computer.
How can I reinstall the network-related files without reinstalling
WindowsXP?
What else could be the problem?
Thanks,
Bill
Sponsored Links
Do you have a router or just a cable modem? If you just have a cable
modem, then what is connecting you other 3 PCs to the cable modem?
"Bill" <bli01@yahoo.com> wrote in message
news:e4oEYZvjFHA.3544@TK2MSFTNGP15.phx.gbl...
> Hi all,
> back.
> cable modem.
> NIC,
> WindowsXP?
> Thanks,
> Bill
Reply to Anonymous
It is also a router.
"Yves Leclerc" <yleclercNOSPAM@maysys.com> wrote in message
news:OqzaQivjFHA.2852@TK2MSFTNGP15.phx.gbl...
>> Hi all,
>> back.
>> the
>> cable modem.
>> NIC,
>> warnings
>> delete
>> WindowsXP?
>> Thanks,
>> Bill
Reply to bill
> Hi all,
> back.
> cable modem.
> NIC,
> WindowsXP?
> Thanks,
> Bill
At a cmd prompt type the following:
netsh winsock reset catalog
This will reset the winsock layered service provider. This may also cause
some problems with some virus scanners. You may have to reinstall your
antivirus program after doing this.
Kerry
Reply to Anonymous
On Fri, 22 Jul 2005 14:53:17 -0700, "Kerry Brown"
>> Hi all,
>> back.
>> cable modem.
>> NIC,
>> WindowsXP?
>> Thanks,
>> Bill
>Kerry
Kerry,
More than just your antivirus. Maybe a firewall or port monitor will go south
on you. Port Explorer from DiamondCS is vulnerable to LSP / Winsock fixes.
Also, the native Windows XP "netsh winsock reset catalog" reset is not the only
solution (and it only works for XP), and is not always successful either. There
are actually 5 solutions which I mention, and I bet somebody else here knows of
another 1 or 2.
<http://nitecruzr.blogspot.com/2005/05/problems-with-lsp-winsock-layer-in.html>
Cheers,
Chuck, MS-MVP [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
Reply to Chuck
"Chuck" <none@example.net> wrote in message
news:e303e15pq3gn14nvushmp1imh69er79gb5@4ax.com...
>>> Hi all,
>>> back.
>>> the
>>> cable modem.
>>> NIC,
>>> warnings
>>> delete
>>> WindowsXP?
>>> Thanks,
>>> Bill
>>Kerry
> Kerry,
> south
> fixes.
> only
> There
> knows of
> another 1 or 2.
I know there are other solutions. I usually use lspfix but in the wrong
hands it can compound the problem. The native fix is supported by Microsoft
and seems to cause the least amount of problems with unsophisticated users.
It is hard to know how much knowledge someone has by a newsgroup post so I
usually use the "do no harm" fix or this case "do the least amount of harm
if something goes wrong" fix.
Kerry
> Cheers,
> My email is AT DOT
Reply to Anonymous
On Fri, 22 Jul 2005 16:47:55 -0700, "Kerry Brown"
>>>> Hi all,
>>>> back.
>>>> the
>>>> cable modem.
>>>> NIC,
>>>> warnings
>>>> delete
>>>> WindowsXP?
>>>> Thanks,
>>>> Bill
>>>Kerry
>> Kerry,
>> south
>> fixes.
>> only
>> There
>> knows of
>> another 1 or 2.
>Kerry
Kerry,
Well, your choice. Just remember that not everybody here has 100% Windows XP
SP2 LANs, and the netsh command isn't 100% effective.
Cheers,
My email is AT DOT
Reply to Chuck
Something to try before muking everything up and building on what Peter G.
said, unplug any network equipment between the computer having problems and
the internet. Wait ... wait ... wait ... a minimum 60 seconds. Go grab a beer
or some coffee. Plug in your modem and give it a minute to settle. Plug in
the other devices giving them time to settle. After everything appears
settled, power on your PC. Once you have a working curser and all
support/background apps have finished loading, open a command prompt window.
On XP, this would be
Click on
Start - Run,
now type in
"command" (without the quotes)
and hit return.
You should see what looks like a DOS session.
Enter the following (without the quotes):
"ipconfig /release" <enter>
"ipconfig /renew" <enter>
Let me know if this helped.
Good luck...
Mark H.
"Bill" wrote:
> Hi all,
> back.
> cable modem.
> WindowsXP?
> Thanks,
> Bill
Reply to Anonymous
There are 1287 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
